Moei, the last traded price for the z tune in Oz was suprisingly high.
Id be curious to know what nismo would charge to "z tune" spec a normal R34 gtr. Not make it a z tune (as of course that wont happen), but to supply and fit all the mechanical parts that matter
Depends how attached you are to your limbs. Would most definetly cost an arm n a leg and possibly your first born. It would be worth it though :P
man, Zele have such cool cars.
If you're hunting for a shmick R34 GTR, you reckon it's worth spending the extra $$ with a mob like Zele?
Unless it's something really rare like a 400R or Z-Tune, most others can be found at auction, for a LOT less money than Zele charge.
I know it can and has been done - it's pretty much throwing the whole Nismo parts catalogue at the car. The Z-Tunes were stripped right back to bare shells and had extra structural mods done though (extra bracing and welding from memory), so the replicas would never be as good as the real deal.
I Honestly have been on the lookout for a Z TUNE ( REAL DEAL ) FOR The past Year , i did see one last year but i f****** up it went cheap for like $150,000 and it only had delivery k's on it i should of snapped it up it was so perfect , if i cant get my hands on one i will buy a r35 ,
Stevo or Kris or anyone if you know of any please let me know.
Thanks
Edited by MRGTR911
Depends how attached you are to your limbs. Would most definetly cost an arm n a leg and possibly your first born. It would be worth it though :(
That price is probably close to correct, you're forgetting internal organs
Yeah ive seen it done aswel, but the question is, is it worth it when you can go the normal path of HKS 2.8 with GTRS's and the rest of the bolt on goodies - is the price comparable to that or WAY out of the ball park?
Thanks
I look at auctions almost every week and Ive never ever seen a Z Tune up for grabs. Damn I might have missed that one.. lol
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
