Found this on tassiecars.com. Not quite my thing (I'm not keen on colours that belong on fruit) but my cousin is. Thought I better ask around, I have seen it near my house before - sandy bay and surrounds.
http://www.tassiecars.com.au/detail.jsp?id...c=2&ti=true
https://www.sau.com.au/forums/topic/266567-does-anyone-in-hobart-know-this-car/
It appears tassiecars.com.au is down. That would be why the link doesn't work. I assume it will be up again tomorrow.
For those that haven't seen it, the car is a bright orange R32 4 door sedan. Black bonnet. Most interesting thing seems to be the custom roof lining.
I'v seen it getting around the northern subs, and all i know is a chick drives it !
