Phatt Audio Concepts (PAC) Phast and Phurious Drive in
Phatt Audio Concepts are hosting a Cruise to Celebrate Fast and Furious 4
We’re calling on the owners of all cruisers, tuners, old and new skool alike... to make this the biggest night that Lunar Drive In has seen in a long time.
We will be honoured by the presence of the Alpine Imprint Nitro,
We will hopefully have one of the city’s best automotive photographers coming along as well to snap a few shots
And as always we will have plenty of giveaways...
There will be judges walking around giving Heaps and Heaps of giveaways from Alpine and Boston and more for the winning cars on display !!
Start Time: 02 May 2009 at 15:00
End Time: 03 May 2009 at 00:00
Lunar Drive In Cinema
Street:
South Gippsland Fwy
Town/City:
Dandenong, Australia
Email: [email protected]
We are hoping to rally the troops for a seriously fun night out and maybe even provide some networking oportunities for all our Phriends and Phamily alike...
...We have some seriously cool giveaways and we've organised 3 movies for ya'll to enjoy...
Entry price will be $19.50 per person at Lunar...
Meet Point will be Phatt Audio Concepts 1/11 Heland Place Braeside, Vic at 3:00pm
We're allowed access to the drive-ins at 5pm which gives us time to have a bit of a perve on each others rides as the sun goes down...
Invite and bring your friends but please so hooning or we won't invite you back...
*If Saturday looks like rain, event will be reshceduled for Sunday*
For more info send an email to
[email protected]
or send me a PM
Unit 1
11 Heland Place
Braeside Vic 3195
Ph: 03 9580 1282
Fax: 03 9580 1283
www.phattaudio.com.au
[email protected]
https://www.sau.com.au/forums/topic/266597-phatts-phast-and-phurious/
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
