i dont know exactly but i dont think its much. The process is same as a clear coat, only the clear has a bit of pearl mixed into it.
a lot of 2pak paintjobs have 2 clear top coats anyway, to achieve that high gloss look. they simply mix pearl into the first clear coat, then spray the second clear coat over that.
https://www.sau.com.au/forums/topic/26660-re-spray/page/2/#findComment-565430
GTBO55, you can actually use pearl both ways!!
the difference is in the result! if you add it to a base coat clear (no gloss) it will come up alot more prominant and look like its over the top!! when you add it to the paint, it takes alot more pearl to get as strong an effect, but is easier to match if you know the ratios!!!
as to adding it ontop of another colour, if its durin the respray it will be easier and cheaper, i paid about $100 for a litre of PPG gold pearl plus the litre of base clear for about the same, then add thinners and hardener!! but i still have about 750ML of pearl left for my next project :P
My paint job has 1.5 coats pearl with clear and 2.5 coats normal clear!!! half coats being mainly a dust coat of the surface!!
there are heaps of pearl colours you can choose from, so get the paint shop to show you a few!!
https://www.sau.com.au/forums/topic/26660-re-spray/page/2/#findComment-566261
In regards to putting it on a standard car, you have to get someone to rub the car back with like 1000 - 2000 grid paper, then spray the pearl and clear, then spray the top coat clear!!
so maybe $400 for paint, $200 for the booth and maybe $500 - $1000 for labour!!
https://www.sau.com.au/forums/topic/26660-re-spray/page/2/#findComment-566262
    • its Masterton Motorplex just over the hill out of wellington.
    • R31 boot how I received the sub, cleaned and today new carpet installed. Thank you Solder!!!!
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
