  • Replies 140
Yo, Ive got a '95 R33 GTR here in sydney for wrecking as it unfortunately can't be complied
It's silver and has approx 44,000 ks, series 1. I can post almost everything from the car, or pickup is available. Will post some more pics in the next few days
R33 GTR rb26dett motor, complete engine with approx 44,000 ks. Compression test came up perfect- ~165-170psi each cylinder
Includes turbos, wiring loom, ECU, manifolds, injectors - $5000 ono
17x9" Axia? (jap wheels) +18 offset wheels with Dunlop Lemans LM702 tyres, front 2 have about 50% left, rears are pretty much on the tread markers
$1000 ono
5sp Manual GTR box, good nick.. includes slave cylinder, shifter - $1000
HKS 3" catback exhaust - $200
Exterior stuff
R33 GTR front bar - paint is cracked + grazed a bit on drivers side. includes blinkers - $400
R33 GTR grille - $250
R33 GTR front guards, includes GT badges and blinkers - $500 pair
S1 headlights - $400
R33 GTR front reo bar - $150
radiator support/ nose cut - $300
R33 GTR sideskirts + rear pods - $200
R33 GTR bootlid + spoiler. Paint is a bit faded on the pass side near windscreen, includes GTR badge - $400
Rear 'Skyline' garnish - $50
Guard liner plastics, both sides - $100
Brake vent plastics - $100 pair
Tail lights - $50 each
Side mirrors - $50 each
Passenger door minis door trim - $150
Drivers door minus door trim/switches - $200
post-35556-1240393680_thumb.jpg post-35556-1240393701_thumb.jpg post-35556-1240393200_thumb.jpg
post-35556-1240393715_thumb.jpg post-35556-1240393732_thumb.jpg post-35556-1240393766_thumb.jpg
Engine bay stuff
R33 GTR afms - $200/pair
R33 GTR airbox & snorkel - $150
Engine Mounts - $100/pair
GTR BM-57 brake master cylinder - $120
Stock dump pipes + front pipe - $150
Stock BOV pair - $120
Stock BOV recirc piping - $100
Stock FMIC piping - $100
Stock Calsonic FMIC, some damage to the bottom though it still holds pressure fine - $50
R33 GTR A/c condenser - $150
R33 GTR radiator- $100
Thermo fan - $80
GTR Washer bottle - $30
fuse box lid - $20
radiator overflow bottle - $20
Charcoal canister - $30
Bonnet lining - $50
post-35556-1240393555_thumb.jpg post-35556-1240393670_thumb.jpg post-35556-1240393834_thumb.jpg
Suspension/brakes/driveline
Front & rear Brembo calipers + pads - $1750 full set ONO
Stock suspension, full set - $250
GTR front + rear swaybars - $150
GTR rear diff - $500
standard swaybars - $80 each
Front upper control arms - $50 each
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
17" space saver tyre - $50
Interior stuff:
R33 GTR front + rear seats + door trim, complete set - $1600 ono, will probably seperate
GTR instrument cluster, carbon fibre look cover ~44,000ks - $250
GTR 3 gauge centre DIN cluster, nismo white face cluster & carbon fibre look cover - torque, oil temp and boost - $175
post-35556-1240393321_thumb.jpg post-35556-1240393332_thumb.jpg post-35556-1240393294_thumb.jpg
Steering wheel with S1 airbag (some wear on the wheel but airbag is great) - $150
Complete Boot interior - $100
Drivers door window switch (suit s1/s1.5 R33) - $80
Drivers window switch surround (s1), bit worn - $30
Drivers door window motor - $80
Passenger door window motor - $50
Large dash surround plastic with clock etc (s1) - $70
Gear stick surround (s1) - $50
Ashtray - $25
Glovebox - $40
climate control - $40
Seatbelts, full set - $80 (will seperate)
If you're after any random bits and pieces that arent listed, shoot me a PM- got the whole car available
Cheers!
Hi which part of sydney are you at?
hey what is the HKS Exhaust ? is it the whole thing from the cat back and what is it made out of ?? PM ASAP
Yep, whole thing from the catback, PM sent
how much for the rear parcel shelf?
Sorry mate parcel shelf is sold
hey mate u still got the brakes???
brakes are sold pending payment at the moment
Front bar and lights still for sale?
Yep front bar and lights still for sale. Pm me if interested
How much for the rear seat?
$200 for the rear seat (both pieces)
hey mate
do you still have the front diffuser?? if its a silver 95 model it should b black and either plastic or fibreglass.
if you still hav it, what sort of condition is it in and if its in good nick how much would you want for it??
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
