EDIT THE FIRST POST THEN
Sorry guys, everything is sold
  • Replies 140
Hey Dude
u Still got The Climate Control? and can u sepreate the headlights i jsut need the front right also with the rio will that jsut bolt straight onto a 1995 S1 r33?
cheers man
Yo, Ive got a '95 R33 GTR here in sydney for wrecking as it unfortunately can't be complied
It's silver and has approx 44,000 ks, series 1. I can post almost everything from the car, or pickup is available. Will post some more pics in the next few days
R33 GTR rb26dett motor, complete engine with approx 44,000 ks. Compression test came up perfect- ~165-170psi each cylinder
Includes turbos, wiring loom, ECU, manifolds, injectors - $5000 ono
17x9" Axia? (jap wheels) +18 offset wheels with Dunlop Lemans LM702 tyres, front 2 have about 50% left, rears are pretty much on the tread markers
$1000 ono
5sp Manual GTR box, good nick.. includes slave cylinder, shifter - $1000
HKS 3" catback exhaust - $200
Exterior stuff
R33 GTR front bar - paint is cracked + grazed a bit on drivers side. includes blinkers - $400
R33 GTR grille - $250
R33 GTR front guards, includes GT badges and blinkers - $500 pair
S1 headlights - $400
R33 GTR front reo bar - $150
radiator support/ nose cut - $300
R33 GTR sideskirts + rear pods - $200
R33 GTR bootlid + spoiler. Paint is a bit faded on the pass side near windscreen, includes GTR badge - $400
Rear 'Skyline' garnish - $50
Guard liner plastics, both sides - $100
Brake vent plastics - $100 pair
Tail lights - $50 each
Side mirrors - $50 each
Passenger door minis door trim - $150
Drivers door minus door trim/switches - $200
post-35556-1240393680_thumb.jpg post-35556-1240393701_thumb.jpg post-35556-1240393200_thumb.jpg
post-35556-1240393715_thumb.jpg post-35556-1240393732_thumb.jpg post-35556-1240393766_thumb.jpg
Engine bay stuff
R33 GTR afms - $200/pair
R33 GTR airbox & snorkel - $150
Engine Mounts - $100/pair
GTR BM-57 brake master cylinder - $120
Stock dump pipes + front pipe - $150
Stock BOV pair - $120
Stock BOV recirc piping - $100
Stock FMIC piping - $100
Stock Calsonic FMIC, some damage to the bottom though it still holds pressure fine - $50
R33 GTR A/c condenser - $150
R33 GTR radiator- $100
Thermo fan - $80
GTR Washer bottle - $30
fuse box lid - $20
radiator overflow bottle - $20
Charcoal canister - $30
Bonnet lining - $50
post-35556-1240393555_thumb.jpg post-35556-1240393670_thumb.jpg post-35556-1240393834_thumb.jpg
Suspension/brakes/driveline
Front & rear Brembo calipers + pads - $1750 full set ONO
Stock suspension, full set - $250
GTR front + rear swaybars - $150
GTR rear diff - $500
standard swaybars - $80 each
Front upper control arms - $50 each
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
17" space saver tyre - $50
Interior stuff:
R33 GTR front + rear seats + door trim, complete set - $1600 ono, will probably seperate
GTR instrument cluster, carbon fibre look cover ~44,000ks - $250
GTR 3 gauge centre DIN cluster, nismo white face cluster & carbon fibre look cover - torque, oil temp and boost - $175
post-35556-1240393321_thumb.jpg post-35556-1240393332_thumb.jpg post-35556-1240393294_thumb.jpg
Steering wheel with S1 airbag (some wear on the wheel but airbag is great) - $150
Complete Boot interior - $100
Drivers door window switch (suit s1/s1.5 R33) - $80
Drivers window switch surround (s1), bit worn - $30
Drivers door window motor - $80
Passenger door window motor - $50
Large dash surround plastic with clock etc (s1) - $70
Gear stick surround (s1) - $50
Ashtray - $25
Glovebox - $40
climate control - $40
Seatbelts, full set - $80 (will seperate)
If you're after any random bits and pieces that arent listed, shoot me a PM- got the whole car available
Cheers!
Would you be interested in selling the external fuel pump/s and injector resistor pack seperately?
I assume you will be selling the injectors with the eng?or i may be interested in those as well prices permitting of course.
thanks for you're time hope to hear from you soon.
"cheers"
Greg(a.k.a footlong) ;)
  • 3 weeks later...
Damn it....never knew everything was sold. You should have edited the front page...took me a long time to come to the end!!
  • 11 months later...
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
