hey guys,
never meant to rebuild my 20 but it cracked a head so i built a new one
it has
-completely reconditioned head..valve grind and seals etc
-ACL race series main and big end bearings
-Mahle piston rings
-Cometic 1.2mm metal head gasket
-Every seal and gasket replaced
-GTR injectors
-Adjustable cam gears
-Gates Racing Triple Strength Timing Belt
-Getting the ECU retuned by MRC Performance with the nistune software
now it comes to turbo...hmmmm
dont have heaps of money so i cant afford the garrett i wanted
someone through work offered me an unused KKR560 turbo for a price i couldnt refuse
IS IT TOO LAGGY? its about the same size as a Garrett 3076
I dont care if it spools up to full boost at about 4000-4500rpm just not much later
advice pls
https://www.sau.com.au/forums/topic/266622-turbo-selection/
To laggy IMHO. RB20 doesn't spool dtuff real well. What kind of stuff do you want to do with the car? If you went to the trouble to go forged internals on a RB20, one might assume you are chasing power levels that would involve turbo's that are going to be laggy anyways. Did you already buy it? Is it bolt on, or are you planning on a manifold and external gate or something. If your going to the trouble of a top mount and external wastegate anyways on a budget, I'm a big fan of Holset turbo's. Search on this board and you'll find some info. HX35 sounds like it would be right up your alley.
Also, can you please remove the HEEELP! from the title since you, in fact, don't actually need urgent help of any kind and you are just asking a question. I'm so sick of clicking on stuff like that expecting so see somebody needing urgent help with something like a blown motor or "I can't get this back together!" and seeing a question about which turbo or what blow off valve.
Edited by Cjmartz2k
https://www.sau.com.au/forums/topic/266622-turbo-selection/#findComment-4551217
Sorry bout that i was looking at buying it then and there almost so i did want urgent help but point taken.
have decided to go with the humble KKR430
want to a tough street car with good circuit and drift ability so got all that stuff plus recaro seat and full whiteline catalog almost lol
also my speedo just randomly stopped working...not the drive in the gearbox or the bottom of the cable...new dash needed maybe?
https://www.sau.com.au/forums/topic/266622-turbo-selection/#findComment-4562152
Can you see the nib spinning around inside the dash portion if you have somebody below the car spinning the other end of the cable?
https://www.sau.com.au/forums/topic/266622-turbo-selection/#findComment-4562380
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
