then i might go for the ISC as im not FULL on doing racing on the track... I would now and then do a little bit of driftinggg .
What do you guys think of the Tien HA's? theres this guy selling them for 1k second hand.... he said there all in good condition.
Thanks guys.
Im not sure who bought up TEIN HA's as they were discontinued 6-7 yrs ago :P
If your on a strict budget and you dont mind a choppy street ride go ISC or HSD, if your after something half decent go Greddy Type S, TEIN SS or MONOFLEX or a better yet a bilstein package... the extra will be well worth it.
Pity you dont have a R32 Geraus as ive got a set of near new ISC's we just pulled out of a customers car, he upgraded to a set of TYPE S he bought of ebay and cant believe the difference.
Edited by URAS
  • Replies 109
Im not sure who bought up TEIN HA's as they were discontinued 6-7 yrs ago :D
and they were not flash even then! steel body, not adjustable lower mount. and twin tube shock. they are great at blowing seals, especially on macpherson strut cars. and I even bought some brand new way back in the day! they were the basic entry level damper adjustable teins.
Blowing seals ya say!....HMMMM....(strokes beard)
just a bit off topics, did anyone ever find out what the spring rates were for the SK groupbuy that was on here a while back? i've got these installed in my r33 (whiteline/bilstein) and i wanted to know if i could be doing better
Depends on what you mean by doing better? Better lap times, better comfort on street etc
Off the top of my head the spring rates were something the lines of 4/3. Search his old threads and I'm sure it will say.
Yeah i bought a set new too for my series 6.... cried in my pillow for days.
Personally I run GReddy Type S and are very happy with them, although the 8kg and 6kg springs do at times when in traffic feel too hard and the car becomes less enjoyable to drive. Get them on a smooth open road and it is smiles all around.
However, my S15 is pretty modded, If you are just going to mod your skyline with mild bolt ons, get somewhere between 250 - 300kw. Drive it mostly on the street with a track day or two through out the year. I HIGHLY recommend TEIN Super Streets. WHY? They are made by an excellent brand - TEIN who only make suspension parts and been in the business for years, 5kg and 4kg springs make for a very comfortable drive around the streets, 16 way damper makes them quite stiff when you want to go for a thrash or have a bit of a drift. And I mean unless you are actually competiting the stiffness is plenty. PRICE - Great value at just under $2000, 2 Year Warrenty, Pillow Ball Tops. For a STREET coil over they really have everything. Their only downside really is they don't go low enough for some people, they go pretty low just not scrub your balls on the road low. I know more than enough people with very fast GTRs running them and not one word of them breaking or having bad performance.
so my recommendation for you are TEIN Super Streets
*Edit* Just noticed you bought HA, good luck with them.
Edited by Jimmy Boy
really, i run type s and in traffic they are fine... are your springs compressed at all or riding properly?
HAs are pretty poor and also very old. like trent said they stopped making them years ago. so yours would be at least 4 or 5 years old and could be more like 10 years old. also, they are twin tube, not mono-tube.
look, if they are in good nick, and your stockers were stuffed then of course they will feel better. but be aware they do like to blow oil seals, especially the macpherson strut models (luckily skylines are not macpherson strut, they have wishbones). I hope you didn't pay much for them. if they were cheap then just enjoy. :D
Also, don't forget- Poorly setup overly stiff car will have a longer stopping distance than a stock car or a car with well setup softer springs/quality shock and some swaybars... another point for springs/bilsteins/swaybars/adjustable bushes.
Roads are shit, conditions change, say no to cheap "coilovers"
uuhhh damm! i thnk i got ripped off.... but oh well.... i got a whiteline rear adjustable sway bar and the coilovers... . hmmmm thanks guys for the help, also they were in good condition... .
Edited by geraus
start saving for the front adjustable swaybar and some adjustable bushes if you dont have adjustable strut tops!
oright cool, so so far i got coilovers there stiff as, and my rear sway bar its pretty stiff to. What else would u guys use to complete my set up. What are the adjustable strut tops?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
