when i went to 10 degrees from 4-5 degrees it was a dream to drive. im now back down to 7 degrees and its still great.
i'm was trying to find a balance for the car as i did some grip work too. with the level of camber i was running i found 7 degrees to work but my suspension guy wanted to see the results when dropping it back to 4/5.
however never got around to doing it as i took the car off the road for a build and have just finally got it back up and running again
  • Replies 109
So what do you guys think of ISC? there 12kg front 8 rear... ? honestly ..
honestly, i think they are cheap suspension. tbh i dont see a lot of difference in cheap suspension, unless they have the horror stories of G4 and D2, then ur really just buying blind as none of them are backed by any credible sources, all u can go off is some bloke who just put in "coilies" into his car and thinks they are tops.
if ur dead set on buying cheap stuff, id buy from Ryan at ISC as he's a genuine bloke trying to run a decent business.
as far as those spring rates are concerned they are overkill unless ur car is a fully built race machine running slicks (but then u wouldnt be buying ISC's), or ur looking for a slippery as f**k car that will have no roll. my biggest concern with cheap suspension is they dont revalve their dampers for each spring rate, so the heavy rate will give u a harsh ride, but wont make the car as solid as ud expect due to the dampers being underdamped, leaving the springs undercontrolled.
Quoted for truth...
Interesting thread, does that mean that King springs coupled with a decent dampener are a better option than a cheap 'coilover'?
Very true about the adjustments, I've made the front a bit harder in mine once and that was it. A mate spent $2.4k getting inverted monotube, pillow ball tops, fully adjustable S13 JIC FLT TAR brand new coilovers, they look awesome, but we took his car for a spin (HR31 GTS) and still felt kind of floaty through the corners, though that was with dampeners on maximum softness. I don't know anyone who plays around with their settings either.
I run Tein Type NA in mine, do any of you know anything about these? I can only find very sketchy details about these, I do have a receipt for the previous owner bying them from SSS Automotive several years ago, so thankfully they're not the ones it has had on for 20 years lol. They are a coilover with a circlip to adjust height to 4 different settings, they dont have a thread like conventional coilovers. I've never bothered changing iride height - I like being able to get over speed humps normally!
It's funny you know, I never used to pay much attention to suspension setups until I went for a ride in a mates A31 $5k of suspension parts in it, and even compared to mine the handling was just fantastic. It made me realise that it's not actually a waste of money to set things up properly.
Edited by bozodos
its hard to say, no point having quality parts if they arent setup well together. for the street i think a softish spring and a well suited quality damper is all u need. there is no "better" but for the street, i just dont see the point in having hard suspension.
just for the record... i adjust mine often enough.... but its really just min for road and max for track :P
yeh, which is really the only way they should be used in those circumstances, using them for tuning is absolutely useless in 99% of cases. but honestly, for the $$ difference, id rather buy a better damper without adjustment for the same $$, a good front damper will have a good digressive curve that will give u the same roll control but give u a softer ride over bumps.
obviously that only goes to a certain point, if u had the $$ ud just go a high end adjustable damper, then learn how to tune ur dampers to a very basic level.
I learned a lot in this topic. Although I don't really do drifting. lol
Its a good thing I can keep up a conversation with my boy sometimes.
Woman needs security… who doesn’t? But I won’t spend too much for my car insurance. I got it for less. You can too… Try it
here.
Tiens are very nice. I mate of mine has them, and I'm actually going to buy a pair myself very soon. Downfall is they are a little expensive, but if you have the cash (and the kev rudd cash :wub:) go for it.
They also come in a wide range of adjustable features, so it something becomes a problem you can always adjust them to your needs.
I replaced my Tein Super Streets with ISC N1 coilovers, myself and a few other on the FDRX7.com also use this suspension and find it holds up quite well on the track.
You can custom order your spring rate as well, I'm happy with my ISC N1's and they're definitely not Chinese copy's as some muppets stated.
This is one of the blokes from darwin running ISC in his FD drift car, it's pretty much no expense spared and he's happy with the ISC's.
Edited by Parag0n
hey guys! Just wanted to say thanks so mcuh for your help . I recently purchased Tien HA's , i installed them myself and they are excellent! heres a pic!
It has hieght adjustment and damper adjustment, When these stuff up i will purchase a pair of ICS's. Thank you guys.
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
