been searching for ages but cant find anything
Im after both the intake and exhaust cam specs for a standard Rb25 with VVT that came out of a R33 skyline
I want to know the;
advertised duration,
duration @ -050" and
the lift
heya
well im not 100% sure if the VVT ones are the same ...
but the ECR33 (RB25DET) stock factory cam specs:
Duration - 240 degrees for both intake and exaust
Cam Lift - 7.80 for both intake and exhaust
and THe pre-set valve timing for intake is 120 degrees
the Pre-set valve timing for exhaust is 117 degrees
hope this helps ya
https://www.sau.com.au/forums/topic/266636-cam-specs/#findComment-4550263
  • 4 weeks later...
