Hey as title states, I'm getting pretty crazyyyy lag playing crysis warhead even on medium setting with AA turned off :D
Anyone here playing this experiencing it?
My system should be able to handle it...
Specs:
Asus P5N-T Deluxe
Intel Core 2 Quad Q6600 OC'd to 3.0Ghz
4Gigs OCZ DDR2 8500 SLI-Ready Edition
512mb 8800GT SLI
Windows Vista 32bit
https://www.sau.com.au/forums/topic/266640-crysis-warhead/
Yeah it should be playable at 1440x900res (or 1280x1024) on Mainstream or Gamer with a few shader settings turned down. You want to aim for at least 30fps but expect some slow down on some action sequences. Also, have you loaded the latest driver (182.XX)?
https://www.sau.com.au/forums/topic/266640-crysis-warhead/#findComment-4550881
Ye, res is too high for that video card... Crysis Warhead while being optimised somewhat over Crysis... still maxes juice on even decent cards.
I haven't played it yet but im expecting it to bring my 4850 to its knee's @ 1680 - i aint even going to try run it @ 1900 lol :(
https://www.sau.com.au/forums/topic/266640-crysis-warhead/#findComment-4550944
tried 1440x900, still getting unbearable lag.. all my other games handle perfectly on full settings and on 1680x1050 :)
And yes 182.50 is installed, i'm pretty sure 8800GT SLI can handle crysis warhead on 1680x1050
https://www.sau.com.au/forums/topic/266640-crysis-warhead/#findComment-4551713
Warhead does support SLI...maybe try disabling SLI to see if that's the cause.
Also, do you know what the CPU % and RAM usage is in game? while unlikely, one of these could be the bottleneck.
Not sure if this is what you're talking about but CPU is on 1% (Doesn't sound right?) and ram is 2.06GB
Edit: Hmm got windows 7 beta put on recently, and in dxdiag it says i've got DX11? lol.. maybe thats the prob?
Edited by SiNNO
https://www.sau.com.au/forums/topic/266640-crysis-warhead/#findComment-4554166
So your running windows 7???
Does the game actually officially support it yet?
I dont think most do as its not officially released yet - add to the fact you dont have a DX11 card, DX11 cards are not due until the launch of Windows 7 officially (not the BETA)
Go back to Vista/XP IMO
https://www.sau.com.au/forums/topic/266640-crysis-warhead/#findComment-4554323
Yeah I totally forgot i had windows 7 running =/
Guess i'll revert back to xp, vista has too many problems
https://www.sau.com.au/forums/topic/266640-crysis-warhead/#findComment-4554615
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
    • Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box.  So i would be good as long as i do not change diff?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
