The 4x100 amp of which you speak is a good value for money amp(make sure you get this one and not the others).
I have had no problems with the 2 amps that I have installed for mates.
There is a really good review of them in one of the import magazines(I forget which). They produced gobs of clean power in a lab test and heaps of people have praised them.
https://www.sau.com.au/forums/topic/26666-jaycar-amps/#findComment-563290
I'll give Jaycar a big rap anytime.
I've done a heap of installs in mates car using Jaycar gear and its pretty good quality and none hav had any problems this far.
more so a value for money thing for me then anything else, and although i dont run em (I use alpine) They're excellent value 4 money and get raps from all the audio mags.
https://www.sau.com.au/forums/topic/26666-jaycar-amps/#findComment-563873
Hippy,
I talk from experience.
I think if you haven't used them, don't diss them until you do =p
I use all "quality" components in my system, Utopias splits, Rockford Fosgate amp etc.
If you can hear the difference between the two simlarily rated amps I will eat my hat.
Sure the internals of the Jaycar MAY be a little cheaper than "quality" amps, but as most of the people already have said there pretty reliable.
What is a quality branded amp anyway?
Pioneer? (laugh)
https://www.sau.com.au/forums/topic/26666-jaycar-amps/#findComment-564619
All good feedback so far so.... JAYCARS it is then!!
thanks guys
much appreciated.
One other thing, I was reading some specs on the jaycar amps and came across "@ 2 ohms" or "@ 4 ohms"?? Whats that all about? Can anyone explain?? (as you can see i'm still a virgin when it comes down to audio gear..)
https://www.sau.com.au/forums/topic/26666-jaycar-amps/#findComment-564670
Basically, (i am mean basic cause i'm not an electronic expert) most normal car speakers run at 4 Ohm, which is a loading which is the head unit (or amplifier) sees when driving the speakers (ie playing music). Normally, with a two channel amp, you would plug one speaker into one channel and a second into the other channel and that setup, the amp would be powering the speakers at XY Watts x 2 channels @ 4 Ohms.
2 Ohm loadings can occur in a variety of ways. You can conenct multiple drivers (speakers) to one channel - not necessarily two either or connect two or more voice coils to one channel. This changes the load placed on the amplifier. This makes the amp work harder and some older amplifiers can't handle the extra load. It's best to ask your audio place how you can best wire up the amplifier to make maximum power if you are unsure as incorrectly wiring up the amp may result in the amplifier seeing too much load and shorting out or melting something.
I'm sure others can explain it better than me but as far as a basic explanation goes, I think that's right.
https://www.sau.com.au/forums/topic/26666-jaycar-amps/#findComment-564682
Bare in mind a few issues when talking about Jaycar amps as they have been tested to output their rated power but not much more at all.
There are also numerous other issues to consider when buying a Jaycar amp too. The Jaycar crossover quality is known to be "less than average" and sometimes require the user to utilise an external one. They don't have much internal capacitance, the damping factor isn't terribly high either and their THD is disasterous when they're loaded down (although this will not bother subs too much). As far as their specs go, they meet them. But when other important factors are considered, the "more expensive" amplifiers (such as Boston and Audison) provide benefits in all of these areas.
https://www.sau.com.au/forums/topic/26666-jaycar-amps/#findComment-564854
Actually,
Pioneer not long ago had amps that I wouldn't touch with a 10ft barge pole.
I'm not sure what there like now.
Sony are pretty good, my friend has a Sony 4x150w it is HUGE and performs pretty good aswell.
FYI Pioneer distribute Rockford Fosgate, I wouldn't be surprised if Pioneer bought them out.
https://www.sau.com.au/forums/topic/26666-jaycar-amps/#findComment-565021
my mate bought a jaycar amp. not sure of the model to power his frount and back spits, after his install (which i will add is probally the cleanest install i think could exist, i mean its insane the effort he went to) it had a rather annoying hiss. he took it back, they swapped it and the one he got did the same thing. he ended up looking arround on the net and found that this amp is known for doing this.
this bit of shit to add to the pile.
https://www.sau.com.au/forums/topic/26666-jaycar-amps/#findComment-565229
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
