ok ill start from the beginning.
about a month ago i got a blitz supersonic bov installed,
had to be welded on with a custom made gasket as an adaptor
was not found. A FMIC was also installed and the bov was welded
onto the intercoller piping. The pod filter was relocated to the
position of the stock intercooler so it would have lots of cold air.
The AFM is inbetween the pod filter and the turbo.
Heres when all of my problem starts.
The car starts to idle very weak on turbo timer
600 - low 700 rpm idle.
Everytime i change gears (around 3000rpm) a single missfire occurs
about 70% of the time. A single pop.
I have tried to resolve the issue by plugging the vaccum line
back into the stock BOV and it seems to run fine, no missfire.
But then another problem occurs.
When i rev over 3k rpm about 4k it starts to shutter and feels like
its loosing a lot of power. I've read around and came across R&R.
i think this might be it, but im not sure.
I've taken it to a few reputable tuners here in melb and they said;
i need to relocate the AFM before the BOV on the intercooler piping,
get a nistune which would cost me quite abit of $$.
I havnt got the funds at the moment and would like for a temporary
fix if possible untill i get hold of some funds.
So if anyone could shed some light on what i should be doing will be great.
From what i've read, im going to get the AFM cleaned, some new
platnium spark plugs gapped at 0.8, tape up the coilpacks
and clean the o2 sensor tomorrow.
As reguards to power. when i first got the car it came with a kakimoto cat back,
pod filter (just sitting in engine bay unboxed) and hks hipermax coilovers.
Power reading was 141.1rwkw.
I feel as if the car is losing power. It does not run like how i bought it.
Thanks in advanced
https://www.sau.com.au/forums/topic/266669-help-few-problems-with-my-34/
update; i've changed the spark plugs today and gapped them at 0.8
the R&R problem seems to have gone but the other 2 problems are still
there !!.
can anybody help me i'm outta ideas
G`day androoh,Do you get misfire with AIRCON switched ON ??? ,let car Idle & see whet happen`s,if you have it just dip,then may be look at COIL PACK`S,cheap quick fix is to COAT with CRC URETHANE SEAL COAT,post-36964-1240482940_thumb.jpgpost-36964-1240483379_thumb.jpg,clean them well ,there is few post`s about this,good luck,cheer`s chuckie
Is it one like in the pic below,
If so you will need to get the recirculating fitting and then plumb back in the return hose from the BOV to between the turbo and air flow meter (MAF) on the intake pipe where the stock pipe has the return.
Edited by TriniGT
If you have the factory BOV that would more than suffice but then you will have to get the factory piping which I am thinking you do not want to do at this point. So just spend a little extra and get the fitting to recirculate the BOV and you should be good.
They always tend to idle a bit lower wen running on the turbo timer, I don't think thats a major issue but 600 rpm does sound a bit too low :) Are you sure it's that low???????
Bout the BOV if it's not a plum back you'll always get that trust me. Bet you any money put the factory 1 back on and problem solved. But neway you just gota do wat the guys said sounds like they know they've used that BOV b4 but sorry I've never seen it.
Standard BOV. This is a well documented problem. Your computer is not able to think. It is preprogramed to work with the equipment it came with. Every time you back off the computer sees a lean out condition and throws in a bunch of fuel, this is the pop you are getting. I could be wrong as every car is different but one thing we all know is the standard R33-R34 will play up without the BOV plumbed back.
Edited by skylinecouple
MAF-metered engines must have a CLOSED induction system in order to run correctly. This means not a single air-leak after the AFM - including; BOV's, oil-filler points, dipsticks, vacuum lines, breathers etc.
As previously stated, you need to recirculate your current BOV (ensuring the return is fed in after the AFM), or return the car to standard.
There have been reports of the factory BOV's leaking, however this is not all that common at moderate boost levels.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
