ok ill start from the beginning.
about a month ago i got a blitz supersonic bov installed,
had to be welded on with a custom made gasket as an adaptor
was not found. A FMIC was also installed and the bov was welded
onto the intercoller piping. The pod filter was relocated to the
position of the stock intercooler so it would have lots of cold air.
The AFM is inbetween the pod filter and the turbo.
Heres when all of my problem starts.
The car starts to idle very weak on turbo timer
600 - low 700 rpm idle.
Everytime i change gears (around 3000rpm) a single missfire occurs
about 70% of the time. A single pop.
I have tried to resolve the issue by plugging the vaccum line
back into the stock BOV and it seems to run fine, no missfire.
But then another problem occurs.
When i rev over 3k rpm about 4k it starts to shutter and feels like
its loosing a lot of power. I've read around and came across R&R.
i think this might be it, but im not sure.
I've taken it to a few reputable tuners here in melb and they said;
i need to relocate the AFM before the BOV on the intercooler piping,
get a nistune which would cost me quite abit of $$.
I havnt got the funds at the moment and would like for a temporary
fix if possible untill i get hold of some funds.
So if anyone could shed some light on what i should be doing will be great.
From what i've read, im going to get the AFM cleaned, some new
platnium spark plugs gapped at 0.8, tape up the coilpacks
and clean the o2 sensor tomorrow.
As reguards to power. when i first got the car it came with a kakimoto cat back,
pod filter (just sitting in engine bay unboxed) and hks hipermax coilovers.
Power reading was 141.1rwkw.
I feel as if the car is losing power. It does not run like how i bought it.
Thanks in advanced
https://www.sau.com.au/forums/topic/266669-help-few-problems-with-my-34/
update; i've changed the spark plugs today and gapped them at 0.8
the R&R problem seems to have gone but the other 2 problems are still
there !!.
can anybody help me i'm outta ideas
G`day androoh,Do you get misfire with AIRCON switched ON ??? ,let car Idle & see whet happen`s,if you have it just dip,then may be look at COIL PACK`S,cheap quick fix is to COAT with CRC URETHANE SEAL COAT,post-36964-1240482940_thumb.jpgpost-36964-1240483379_thumb.jpg,clean them well ,there is few post`s about this,good luck,cheer`s chuckie
Is it one like in the pic below,
If so you will need to get the recirculating fitting and then plumb back in the return hose from the BOV to between the turbo and air flow meter (MAF) on the intake pipe where the stock pipe has the return.
Edited by TriniGT
If you have the factory BOV that would more than suffice but then you will have to get the factory piping which I am thinking you do not want to do at this point. So just spend a little extra and get the fitting to recirculate the BOV and you should be good.
They always tend to idle a bit lower wen running on the turbo timer, I don't think thats a major issue but 600 rpm does sound a bit too low :) Are you sure it's that low???????
Bout the BOV if it's not a plum back you'll always get that trust me. Bet you any money put the factory 1 back on and problem solved. But neway you just gota do wat the guys said sounds like they know they've used that BOV b4 but sorry I've never seen it.
Standard BOV. This is a well documented problem. Your computer is not able to think. It is preprogramed to work with the equipment it came with. Every time you back off the computer sees a lean out condition and throws in a bunch of fuel, this is the pop you are getting. I could be wrong as every car is different but one thing we all know is the standard R33-R34 will play up without the BOV plumbed back.
Edited by skylinecouple
MAF-metered engines must have a CLOSED induction system in order to run correctly. This means not a single air-leak after the AFM - including; BOV's, oil-filler points, dipsticks, vacuum lines, breathers etc.
As previously stated, you need to recirculate your current BOV (ensuring the return is fed in after the AFM), or return the car to standard.
There have been reports of the factory BOV's leaking, however this is not all that common at moderate boost levels.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
