Whats The Chances Of Making It Fit Without To Much Trouble?
harlo peeps
Whats the chances of getting a set of 19x9.5 +22 to fit on a 32gtr ... have a sneaky feeling im going to have the worst turning circle in the world if i put these on. I dont think ill really need to remove the guard liner as my suspension is ultra stiff so theres is hardly any travel.
passing though on a set of rims i know for sale.
What makes you think theyre staggered? Its a GTR, they should all be the same.
I have 18x10+22 on my 32 GTR and theyre fine. 285/35 tyres. Its pretty low too. No rubbing. I think with the less width youll be right.
All depends on your tyres, ride height and camber too. You might want to run a 265 or even 245 with a low profile to get the clearance.
saw his 4 sale post (8.5 front n 9.5 rear) ..
my car isnt quite that low .. but your right ... ill have to look into camber and tyres ... dont really like running stretched tyres.
im using 235 on 18x9 atm.
harlo peeps
Those offsets will be fine Cal.. don't be a pussy :dry:
Im running R34 GTR rims With Nitto Invo 275/35/18 on my R32 GTR, its sittin low, so only rubs on bumps and fast turns.
i might have to remove the plastic under the guards? not sure?
Gotta love Nokias reliability perfect picture 1time shithouse the next Long Live the Nokia N96
My 2c worth
Edited by GOD2LA
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
