hey i have recently converted my car to manual and now when the car is going to take off it feels like the clutch isn't lined up 100% and there is mad vibration going through the tailshaft! enough to hear it knock on the tunel a couple of times.
anyway i called my mechanic and explained the situation and said that the clutch couldn't be lined up incorrectly or it just won't work at all, he then explained it could be a warped fly or pressure plate also about ceramic something rather could cause vibrations, but it is an organic clutch soo that was ruled out.
just need to know if i have installed the clutch slightly out can it cause the problem? can i just get it re-aligned?
any info helpful
cheers
jason
https://www.sau.com.au/forums/topic/266690-clutch-issues/
Your mechanic is basically correct - if the clutch assembly isn't aligned correctly, then the gearbox just will not go back on.
Did you disassemble the driveshaft during this swap? Or is it a different driveshaft from the original?
https://www.sau.com.au/forums/topic/266690-clutch-issues/#findComment-4551097
same shaft as before,
another mechanoc mate says it could be the spigot bush? but it runs fine with clutch out.
steps i am taking now is machined flywheel, brand new clutch and getting a mech to assemble the clutch.
fingers crossed!!
any other suggestions??
https://www.sau.com.au/forums/topic/266690-clutch-issues/#findComment-4552119
did you know the history of the gearbox you purchased?
sounds like it could be the rear main shaft bearing.
if the bearing is gone, it can allow the shaft that your tailshaft connects to to move.
hence causing movement and vibration. put it up in the air and try moving the front of the tailshaft by hand, you should get very little movement.
hope this helps.... :blush:
https://www.sau.com.au/forums/topic/266690-clutch-issues/#findComment-4554882
okay soo it is still doing it i have checked the rear main bearing and it seems to be fine.
i did however notice that when i installed the new clutch the spline/shaft (the thing at the front) had a lil movement in it like side to side,
im not sure but i dont think that it should have play, am i right?
jason
https://www.sau.com.au/forums/topic/266690-clutch-issues/#findComment-4572240
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
