whos been to court for traffic infringment?
Hi,
Just wondering who has gone to court over a traffic infringment. Would like to know how long till your summons arrived, and how much time u had between that and your court appearance.
Also, I have heard that 12months after the offence they can no longer prosecute you.. anyone know if this is true?
thanks
dave
mine talk about 2 months to come, when to court about a month later pleeded guilty, got a diversional programm, one of the requirement was i had to do a safe driving coarse, did it with kevin flynn at driver dynamics what can i say a great experience very educational aswell i would recomend anyone of use just to do it to improve your driving skills.
3 months when i decided to contest something.. good way to delay getting points, and paying the fine. Clog up the court system, its all good - will make the government rethink its revenue system if everybody took things to court.
scotty... Um, can't remember exactly.. but depends what it is. Basically if you plead guilty, its not put on your record, the and fine (decided by the court rather than the TINS system) and or/points just goes through. Thats what happened to me anyhow.
If you plead not-guilty you have to come back for the hearing, and if i think you are found to be guilty it goes on your record.
Depends what the charge is i guess. Serious ones are always going to be put down.
I have a friend who used to be in a police prosecuter. Basically, if your found guilty in court its up to the judge to decide wether its a conviction or not. If the judge decides to convict you then you have it on your record for life (yes, u can get a criminal record for speeding :)). So the main thing is, dont go to court just to delay points as the judge will get pissed off and give u a conviction.
In my case, I was caught doing 110 in an 80 zone (overtaking) and the cops pulled me for 110 in a 60 zone, overtaking on double lines (were no double lines) and no p plates (had p plates).
The next day I went to the local station to lodge a formal complaint as after I was pulled over i was called a few swear words and the police made me come to their car rather than getting out and coming to me! When I went in they made me talk to the officers that had pulled me over (not very good practice for someone wanting to make a complaint against them). I then told them I would like them to re-issue the ticket at the correct speed zone and their response was "YOU DESERVE IT".
so after writing formal complaints and letters to civic complaince to drop the ticket I had everyone telling me that there was nothing they could do, and i had to go to court.
So yer, here i am now, waiting and hoping that it never comes!
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
