i got a reverse camera, but thats pretty common.
AND door sill extras!
I have reverse camera, pop-up screen (sat nav), black leather power/heated seats and umm... I know there was something else, but I just can't remember :(
Reverse camera is not as common as you may think.
btw, pop-up screen was an extra for RS/RX's.
Super Fine Hard Coat [sFHC] (what Andy mentioned to protect the paint)
LCD Screen (TV / SatNav)
Twin Electric Sunroof
Nissan Performance Exhaust with Sound Control (cat. back)
Nismo S-Tune Suspension
Aero Bodykit
Door Sills (lol... a little shot at iamhe77)
NO reverse camera :dry:
ohh in that case i have
TV/satnav
Leather seats
Aero kit
metal door sill thingos
and thanks andy, the RX gets more airbags than the RS! i knew there was something else! i have 6 or 8, i cant remember which
oooooh. that's a huge bragging point :dry:
*tapes some pillow's to his interior*, blah :P
TV/satnav
Leather seats
Aero kit
Huh? How do you know if your RX have 4 airbags or 6?
Andy was saying his ARX had a Safety Pack option included which game him 6 airbags.
My ARX had the safety pack, which is 6 air bags including side curtin and center rear lap sash seat belt.
Cheers
Andy
Andy, did you find this info on FAST or somewhere else (Ben perhaps?).
Also, when you say "center rear lap sash seat belt" do you mean a 3-point seat belt in the middle?
Edited by iamhe77
Yes, Ben told me when I bought it. Plus you can see the markings on the B piller and side of the front seats.
Yes, 3 point seat belt in the middle. That retracts to the side.
Cheers
Andy
just want to see what factory options different model or year m35 stageas came with
Twin Electric Sunroofs
Cargo Blind
Cargo Net
Bose Stereo with in built Sub-woofer in the spare tyre - farking awesome stezza. . .
Electric heated leather seats
Wind deflector thingies on the windows. .
Extra Storage compartments due to non DVD screen and toll tag stuff. . . which I dont mind as they are very useful spots to store crap. . .
All those extra air bags, side curtain etc. . .
And all of the normal AXIS stuff. . .
I got auto folding mirrors......
and an ioniser, that we pulled out after 5 minutes of ownership..
Momo half wood steering wheel, wood trim centre console, Panasonic sat/nav, that is circa 2003, in a 2001 car, wind deflectors, including rear one on boot, also number plate trims that are now stored in the boot, as a VIC numberplate is too wide to use it...
and the usual non funtioning 6-disc CD with ER0 message...
Still love it...
My wife has the 2002 NM35, It has some snow package so it only has one reverse light the other is a fog light. The snow control is down by the shifter I think it also turns on heated mirrors outside. It has inteligent cruise control (buttons located on right coloum of steering wheel), dual sun roofs, It also has a remote by the cup holders that turn either or both of the front cameras on viewed on the pop up screen while parking. It was also fitted with mats and sunoof and window wind shields.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
