Hi, I know I'm new on this forum and this is my very first post here, but I can't seem to sell my turbo on the other forums, like zilvia or nico, so i decided to try here. Well I had a rb20det, decided to swap it out. Now I'm left with a brand new hks turbo that I have no use for. I bought the turbo for over 2000 usd, I'm asking for 1500 shipped.
HKS GT2835 Pro S - 420 PS Output
COMPRESSOR:
-Wheel- 56 Trim - 53.1 Inducer / 71.1 Major
-Housing- 100 Inlet / 50 Outlet - 0.50 A/R
TURBINE:
-Wheel- 84 Trim - 56.5 Major / 51.8 Exducer
-Housing- T3 inlet / Outlet spec:
Internal GT-Pro; 0.68, 0.87 A/R
And here is the website,
http://www.hksusa.com/products/?id=1670
1500 shipped Usd, I will only accept paypal.
Email me at [email protected] for a faster response.
I'm located in Philadelphia Pa, USA.
Edited by foamcup
I understand that this is my only first post here, if you need any info on me, picture of my id, me holding the turbo with my id, i will do that so. Please email me and I'll give you my contact number if you want to even talk to me.
All emails replied. Thanks!
Yes pay pal only haha, I'm verified and have a premier account.
Bump, you don't get a brand new hks turbo for this price often. I'm really taking a big lost here. I have some interest but no one is pulling through, anyways first come first serve, i won't hold the turbo. I need it gone.
paypal this item and you might have some luck.
Yes 1500 US dollars shipped to you.
I waited months for this turbo from japan to get to my house, by the time it did I lost interest in my rb20det and 240sx. Anyways, I have original receipt for the turbo as well that I will include.
i cant believe this isnt gone yet - ill refer this to my mate with an s15, hes broke but maybe he'll pull some cash from somewhere, he usually does - he has an s15 after all
Since your new here and no one knows you, it would be easy to scam someone over 1,500 since your in the us. It be hard for you to sell since it's a risk someone has to take. It looks shiny and good but it could be blown and you had it
Polished. Just what I think, sorry if I sound skeptical but it happen to me before.
Yeah, its even harder to sell in the states, everyone is broke and we don't get skylines here, and for the skylines that does make it over, you rarely to never see them unless you're at a show or a event. Well, what else can I do to make one feel at ease, to buy from me? If you search my name, you'll see I have sold many things on zilvia.net, 240sx.org. Anything else that a buyer would like me to provide please email me and let me know, I'm more than willing to work with you.
Anyways, I just purchase a new toy. Enjoy
73 te21 52,000 miles, all original.
I also have a f20c ae86 = )
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
