Built Rb26 + Top End Parts - Wa (ready For Inspection Can Build Complete If Required)
hi, got a built rb26 engine for sale heres the list
-Brand new gtr block from nissan (86mm bores)(cryoed prepped line bored etc etc)
-Tomei oil restrictor
-R33 gtr crank (cryoed balanced drilled)
-Crower rods (these were made to order apparently the best of the best according to in tune performance which is where most of this stuff came from)
-Cp pistons with cp rings and gudgeons
(all assembled)
-Head is from a r33 gtr
-Ported and polished
-Jun valve springs
-Jun 272 cams
-engine and head prepped and machine work done by ADS
(can be assembled if required)
(Also got all the original throttle bodies and manifolds and stuff)
ive got a lot of other stuff too depends on what ppl want
- ATi balancer
- High energy sump and pickup ( to suit Rwd)
- Blitz drag cooler
- 840cc injectors
- Jun oil pump
- N1 water pump
- HKS timing belt
-OS giken cam gears
- Clear cam gear cover
-Painted rocker covers in a nice dark blue
-Microtech lt12s wired to suit rb26
- Jun 260 cams that i changed early on
- trust oil cooler kit with filter relocation
Price is depending on what your after so if any of this stuff grabs you just pm me and ill give you the price. ( please dont hassel me about not providing a price i dont want to give it to the highest bidder or anything i just want to sell as much as possible in one go. ( Prices will be decent too i want this stuff gone!) If someone wants the bottom end with no head thats cool or if they want the head etc or the sump whatever im flexible!! pics of various stuff available as of tomorrow
  • Replies 53
- ATi balancer
- Blitz drag cooler
- 840cc injectors
- Jun oil pump
- N1 water pump
- HKS timing belt
-OS giken cam gears
What is the pricing on this stuff ?
Bottom end is assembled and will be sold as one piece thats
cp pistons, crower rods, king bearings, arp main studs, new nissan block, cryo balanced polished crank, tomei oil restrictor and crank sleeve for oil pump. complete ready to go. $5000 (Perfect if you have popped your gtr engine) ( ive got 3k worth of work at the machine shop plus parts this is a crazy price so not negotiable sorry.
Head will be assembled on thursday with 272 cams $3500 ono
Cam gears are yours for $300 - cerbera
Clear cover thing is $150 its a genuine trust/greddy one
Jun cams are 264 9.7mm lift $550
Blitz drag cooler is 600x260x100 to suit gtr $900
Trust oil cooler kit (to suit r33 gtr places oil cooler in front of radiator) is $850
Microtech LT12s wired and tuned for standard rb26 running 15 psi made 340 at the wheels $900
High energy sump suit rb26 RWD skyline/silvia $900
dont mind posting gear nationwide, prices are negotiable, pics can be sent on request
Very interested in top end, willing to buy just need to find out how engineering it to a R34 goes, since its from a 33, that and want to do a rb30 bottom end from a series 2 VL so not sure how engineering certs go on that since they are both older models than my crapbox.
If you know anything about that or can lighten the issue up for me id be 99% willing to buy the top off you and maybe other things depending on what ill need for set up, might be interested in the sump aswell if you message me.
PM me if you want to sell. [email protected] if you want to speak to me personally or email me.
Thanks,
Josh
I have a few ideas dude but if i was you id search through the tech section is this forum because theres pretty much everything you need to know about rb30's in there. ( and even some stuff you dont need to know). However the head has changed its getting assembled with 264's instead of 272's
272's getting sold seperatly for $550
just a reminder =
* All items for sale are brand new *
and jun oil pump,ati balancer,n1 water pump 840cc injectors and hks timing belt are sold
Trust/Greddy oil cooler kit includes oil filter relocation kit too cause ive had a few questions about that
Edited by mrsparkle
 Share
    • Brand new r34 gtt box
    • What is the go to gearbox these days for a RWD RB? Back in the day VG TT boxes were cheap and strong. Seems they are as expensive as an RB25 box these days. What are the options without remortgaging the house?
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
