  • 3 weeks later...
  • Replies 53
yeah 272's installed in the head now
still for sale
-bottom end
-sump
-intercooler
-short shifter to suit a rb25det gearbox
offers-
the head and the 272 cams are sold
still need to sell the
- rb26 bottom end ( cp pistons, crower rods, tomei oil restrictor, prepped and balanced crank with polished journals, brand new r33 block cryoed and linebored, ARP main studs, king bearings all assembled $5000 brand new)
- High energy sump to suit rwd rb26 its 8.5 ltrs capacity and is a must have if you want your rb26 to stay in one piece. will fit rb26 skylines or silvias $600 brand new
- Blitz drag cooler suit r32/r33 gtr 600x260x100 core brand new $600
- c's shoft shifter to suit rb25det gearbox brand new still in packaging $200
well, i know i'm a tool. :banana:
but tell me if u keen to separate 86mm pistons & cranks. PM maybe?
cheers!
well, i know i'm a tool. :thumbsup:
cheers!
sorry not willing to seperate but unless you had a brand new block you wouldnt be able to use them anyway
sorry mate, cant PM because i have posted enogh, is the head still for sale?
the head has been sold
all i have left is intercooler
bottom end
sump
short shift kit to suit rb25det gearbox
greddy intercooler piping to suit r32/r33 gtr
intercooler and piping are sold
sump still for sale -offers
c's short shift kit still for sale suit rb25det 5 speed- offers
  • 3 weeks later...
  • 4 weeks later...
dude those were literally the first things to sell - only thing left is the sump and the shoft shifter
  • 11 months later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
