hope i don't get flamed about using the search funciton i tried. (i'm usually on ns.com where they can be real c#$%s)
i got my m35 wagon and just wanted some parts lists (could only find 34) i got an 01 vq25det. if anyone knows wat oils, for differnt parts i.e. eng auto diffs transfer. also wat filters like air an oil. i here the fuel filter is in the fuel pump. these waongs are wicked.so any help to maker her purr all the more would be greatly appreciated. does anyone know anything bout converting the dvd sat tv stuff. cheers liam
Edited by liam s
https://www.sau.com.au/forums/topic/266766-new-m35/
Have a read through the M35 Info thread (stickied) - specifically towards the end. I know there's a lot of pages there - not sure if someone's added the info to the first page yet or not. Another option is to search and do the results as posts rather than threads...
Hope this helps. But if you do find out this info, and its not listed elsewhere, maybe create a thread and post it all up. >_<
https://www.sau.com.au/forums/topic/266766-new-m35/#findComment-4552672
+1 on all this covered before, mostly its on the first few pages. and yeah NS.com is full of useful information if youre a retard :banana: no offence to any NS.com member unless i dont like you, in which it was meant to be offensive.
anyway welcome and post some pics of your Stagea! Where are you located? there is a sydney meetup every thursday evening, also located in a thread...... haha
https://www.sau.com.au/forums/topic/266766-new-m35/#findComment-4552716
i'm in melbourne so i can't make the cruise but i will look through that post again near the end cause the first five or so pages don't help and the last few are the same. does anyone know anything about the sat tv dvd for translation cause i saw some guy sellin one on youtube in melb claiming he had it converted. also i have a jap owners maual if anyone wants to translate but its an owners man not the service man. cheers liam
https://www.sau.com.au/forums/topic/266766-new-m35/#findComment-4553969
Have you got the manual as a pdf? If so send it and I'll get the translation started. If you have a book send it to me by mail, I'll scan it and then create a translated one. I've been hunting for a service manual to do the same so if anyone can provide either an electronic or hard copy one I'll get onto it. PM me and I will give you an address.
Related to your post, I'm new to Stagea's too (in fact mine is being delivered in an hour :/ ), and I've found this forum great. Read through the stickys on the front page and you'll find lots of info on most of what you're asking. Then do a bit of a search. I found 90% of what I wanted though through either the stickys or searching. The DVD thing is all over here and you can get it both ways.Long story short there's no translated hack available for the factory system yet and one that works will be an aftermarket system fitted in place of the OEM sometimes using the factory screen (NTSC) and sometimes using a replacement screen.
Edited by Houdini
https://www.sau.com.au/forums/topic/266766-new-m35/#findComment-4553987
The V35 manual probably wont help with parts but if you want genuine parts, your local nissan dealer should be happy to import them for you.
If you want aftermarket, there's a lot of stuff for C34's but I find that M35's are still pretty hard to find parts & info for.
https://www.sau.com.au/forums/topic/266766-new-m35/#findComment-4555047
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
    • I have a wheel cleaner pokie thing which is a glorified microfibre rag on a stick, and there is not sufficient clearance between the caliper and the barrel to clean that section. I just roll the car forward 500mm and have another shot at each wheel.
    • The "rag on a stick" is a easy way to fit in between the wheel spokes into all of the barrel Albeit I do have 10 spokes on the MX5 which limits the access to actually jam my hand in to clean the barrel, but it was also makes much easier to clean the 5 spokes on the Dunnydoore with it as well, as you don't have to worry theΒ  caliper getting in the way if you have at least about 15mm space between the caliper and barrel This of course depends if you actually have the clearance between the barrel and caliper, and the amount of OCD you have to get the barrels as clean and shiny as the face of the wheel The thing is bendy as well so you can actually shape it to conform to the inner lip of the barrel Β
    • FWIW, as well as a basic immobiliser/remote unlock (all basic units give you those 2 things), I would also install a 4g tracker in any car I cared about. Just hide it anywhere that won't be found in a rushed look and preferably get something with a built in battery backup so it stays online for a while when the battery is removed or flat While its not a car, when our car trailer was stolen in that den of crime Sydney about a decade ago, the cops were watching from the bloke's neighbour's lawn within about 2 hours until he started swapping the plates and putting up the gumtree ad.Β Β  Obviously it is still not undefeatable (eg parking it up for a few days somewhere without sky sight) but it greatly improves your chances of getting it back quickly and with less damage
    • Instead of magic keyphrases I wonder if something can be done with auto complete. Similar to how user names are handled already. When you type '@' and follow with letters, it'll search across all usernames. It might work to have the same for forum topics. Some key to trigger it and then text search across all thread names and it'll insert the name and URL when pressing enter.
Γ—
Γ—
