Hey guys, searched for this but no cigar >_<
I always thought that it doesn't make a difference, but I heard some people say that you're meant to refill before the needle goes down to the last 1/3 or 1/4 or so (something to do with direct fuel injection/clogging up your fuel filter???). I tend to refill when the light goes on. The fuel gets sucked from the bottom of the tank anyway, doesn't it?
If you refill at 1/3 full every time, won't that mean you will just have more and more % stale petrol in your tank for longer?
eg.
1st tank: 1/3 batch A, 2/3 batch B
2nd tank: 1/9 batch A, 2/9 batch B, 6/9 batch C
3rd tank: 1/27 batch A, 2/27 batch B, 6/27 batch C, 18/27 batch D
etc, etc you get the idea
Granted stale petrol will never reach more than 1/3 of the tank, but with each filling, a smaller fraction of that petrol you put in last year still remains...
https://www.sau.com.au/forums/topic/266776-when-to-re-fill-fuel-tank/
Well you pretty much answered your own question in parts, as in "stale fuel at the bottom of the tank" and "the fuel get sucked from the bottom of the tank" !
Main reason to refill before a 1/4 or lower is stop the pump picking up so much crap from the bottom of the tank, ie - more fuel=less condensing of contaminents, also helps prevent surging on acceleration and cornering.
Takes a fair while for fuel to go off or stale, unless its race fuel which has a shorter shelf life.
If your running a standard fuel pump you will be fine to run it pretty low. Some aftermarket pumps dont like it when the tank drops below a certain point. Will let someone with a bit more knowledge about fuel pumps explain this.
Oh ok, I see. I guess some aftermarket fuel pumps work a bit differently to the stock ones.
i like to fill mine up around half tank.
Reason for this? I like to be prepared. I hate it when i go out and i see my tank is nearly empty and i have to go out of my way to fill it up. If i fill up around half tank it means i can wait until i pass by a BP and fill her up when its convenient to me. If however its at 1/4 tank left i have to go out of my way to fill it up.
From my experience its never good to run a car on less then a 1/4 tank. As hard cornering and launching or even braking the petrol can run away form the pick up point.
Stop being stingy people and just fill her up.
lol i run mine to near bone dry as im a cheap bastard and cant always afford to fill up :)
lol
as do i, but if i run it really dry my engine light comes on and stays on till about 15 minutes after i have filled up lol.
alot of ppl saying that you'll pick up shit from the bottom of your tank is bullshit in most cases, i cant member where i saw it but a dude took his fuel tank off his r32 gtr and the bootom of the tank had no crap whats so ever,
remember there is a sock on the end of the fuel pump and a filter in engine bay
i was testing how out my fuel guage is
the light hasn't come on yet but i'm well and truly out of fuel
was strange tho cos i drove it the day b4 it ran out and no signs of it getting low (no fuel light but low guage)
went to start it the next morning and it barely ran
jarry can run for me now :)
least i know where the limit is now - i hate being poor
I tend to fill up when the light comes on. Not because I'm cheap (beleive it or not people, you're still buying the same amount of fuel in total regardless of if you fill up twice with half a tank or once with a whole tank), but more because I'm lazy so don't stop for fuel unless i'm forced to :D
well took the fuel pump out after having run it pretty much dry and was quite suprised what i found
it was spotless and there was cool baffles everywhere
so there was not much crap on the pump either, put some fuel in it and took it to the servo
runs well and not a problem
moral of the story, maybe there isn't as much crap in there as you think
i have never ever let my fuel go low enough for the light to come on....there realy is no reason as to why u would let ur light come on and continue driving for another 50kms
i always top up when my fuel gets to 1/3
if u continue to let the light come on, ur more likely to suck up rubbish...but thats what the fuel filter is for i guess ;)
mythbusters ahoy
the pump is ... on the bottom of the tank
so regardless of how much fuel is in the tank
it sucks from the bottom with a sock (filter)
and there is an inline fuel filter before the fuel rail
so running empty, does no harm
Thanks Paul, that's what I thought.
Just had my car serviced today and the fuel filter (which I doubt has ever been changed since the car was made 8 years and 55k ago) was pristine, despite only filling up when the light goes on every time. Put my mind to rest.
mythbusters ahoy
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
