Hey guys, searched for this but no cigar >_<
I always thought that it doesn't make a difference, but I heard some people say that you're meant to refill before the needle goes down to the last 1/3 or 1/4 or so (something to do with direct fuel injection/clogging up your fuel filter???). I tend to refill when the light goes on. The fuel gets sucked from the bottom of the tank anyway, doesn't it?
If you refill at 1/3 full every time, won't that mean you will just have more and more % stale petrol in your tank for longer?
eg.
1st tank: 1/3 batch A, 2/3 batch B
2nd tank: 1/9 batch A, 2/9 batch B, 6/9 batch C
3rd tank: 1/27 batch A, 2/27 batch B, 6/27 batch C, 18/27 batch D
etc, etc you get the idea
Granted stale petrol will never reach more than 1/3 of the tank, but with each filling, a smaller fraction of that petrol you put in last year still remains...
https://www.sau.com.au/forums/topic/266776-when-to-re-fill-fuel-tank/
Well you pretty much answered your own question in parts, as in "stale fuel at the bottom of the tank" and "the fuel get sucked from the bottom of the tank" !
Main reason to refill before a 1/4 or lower is stop the pump picking up so much crap from the bottom of the tank, ie - more fuel=less condensing of contaminents, also helps prevent surging on acceleration and cornering.
Takes a fair while for fuel to go off or stale, unless its race fuel which has a shorter shelf life.
If your running a standard fuel pump you will be fine to run it pretty low. Some aftermarket pumps dont like it when the tank drops below a certain point. Will let someone with a bit more knowledge about fuel pumps explain this.
Oh ok, I see. I guess some aftermarket fuel pumps work a bit differently to the stock ones.
i like to fill mine up around half tank.
Reason for this? I like to be prepared. I hate it when i go out and i see my tank is nearly empty and i have to go out of my way to fill it up. If i fill up around half tank it means i can wait until i pass by a BP and fill her up when its convenient to me. If however its at 1/4 tank left i have to go out of my way to fill it up.
From my experience its never good to run a car on less then a 1/4 tank. As hard cornering and launching or even braking the petrol can run away form the pick up point.
Stop being stingy people and just fill her up.
lol i run mine to near bone dry as im a cheap bastard and cant always afford to fill up :)
lol
as do i, but if i run it really dry my engine light comes on and stays on till about 15 minutes after i have filled up lol.
alot of ppl saying that you'll pick up shit from the bottom of your tank is bullshit in most cases, i cant member where i saw it but a dude took his fuel tank off his r32 gtr and the bootom of the tank had no crap whats so ever,
remember there is a sock on the end of the fuel pump and a filter in engine bay
i was testing how out my fuel guage is
the light hasn't come on yet but i'm well and truly out of fuel
was strange tho cos i drove it the day b4 it ran out and no signs of it getting low (no fuel light but low guage)
went to start it the next morning and it barely ran
jarry can run for me now :)
least i know where the limit is now - i hate being poor
I tend to fill up when the light comes on. Not because I'm cheap (beleive it or not people, you're still buying the same amount of fuel in total regardless of if you fill up twice with half a tank or once with a whole tank), but more because I'm lazy so don't stop for fuel unless i'm forced to :D
well took the fuel pump out after having run it pretty much dry and was quite suprised what i found
it was spotless and there was cool baffles everywhere
so there was not much crap on the pump either, put some fuel in it and took it to the servo
runs well and not a problem
moral of the story, maybe there isn't as much crap in there as you think
i have never ever let my fuel go low enough for the light to come on....there realy is no reason as to why u would let ur light come on and continue driving for another 50kms
i always top up when my fuel gets to 1/3
if u continue to let the light come on, ur more likely to suck up rubbish...but thats what the fuel filter is for i guess ;)
mythbusters ahoy
the pump is ... on the bottom of the tank
so regardless of how much fuel is in the tank
it sucks from the bottom with a sock (filter)
and there is an inline fuel filter before the fuel rail
so running empty, does no harm
Thanks Paul, that's what I thought.
Just had my car serviced today and the fuel filter (which I doubt has ever been changed since the car was made 8 years and 55k ago) was pristine, despite only filling up when the light goes on every time. Put my mind to rest.
mythbusters ahoy
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
