Stop wasting money on iridiums/platinums, put a set of copper BKR6E in or BCPR6E in and change them every service. You'll constantly have fresh plugs, won't have missfire issues since they are gapped to .8 and not 1.1 and they are cheap.
Edited by PM-R33
excuse my ignorance, but do BCPR6E = BCPR6E-11 ? When I put BCPR6E into google it comes up as BCPR6E-11. What does the 11 mean on the end?
I have misfire problems and plan on running these plugs with my new splitfires, should be OK?
The NGK site says recommended plug = PFR6A-11 (Platinum)
Iridium equivalent = BCPR6EIX-11
Thanks mate you're spot on with part number, I did find out the info on platinum but no ref to iridium, However good people at Just Jap Kirawee had them only recomended for RB service which made it easier.
The reason I went with iridium is I don't wont to replace plugs every service given that car is running std boost and will remain same and also set of iridiums was cheaper from JJ then set of platinums from elsewhere.
Big service next weekend along with 300v chrono, filters brake/clutch fluid (motul), and Nissan coolant as well.
Can't wait to take it out for a drive after all that.
:P
Dave
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
