So i just bought a 2nd hand one. Ill pick it up tonight or this weekend :)
Those of you that have one already, do you have an electronic version of the japanese installation guide? i have the english version but its for US cars, and i think the injector and ignition pins will be different in the ECU.
ill take pics while installing and make an FYI thingo for future people that wish to perform the work themselves
thanks guys!
https://www.sau.com.au/forums/topic/266854-m35-emanage-ultimate/
I will go and pick it up for you if you like? :(
I need all performance advantages I can get :)
If I had have known the little blocked hole on the airbox would have made such a difference to sound I would have done it when I got it lol It sounds different but beefier, performance wise it feels like it achieving better air intake, even with low fuel levels.
Thanks for that :D
thanks guys!
I will have to check when I get home.
I have the CD, but I think it is just has the installation program on it.
For a wiring diagram, check the pdf in the M35 Info thread
thanks mate! i think i have a firmware update for it from the japanese website, but i think ill need the support tool. im guessing this one is just USB not like the blue that needed the dongle to convert that shit to serial.
thats easy, ill need an A to B cable. no need for a pic thanks mate :D
who did your installation of the emanage? the ignition and injectors will be the worst, im guessing ill need to enter the engine bay and check wire colours :)
Not installed yet.
Sitting in my parts cupboard... waiting patiently to be installed.
Haven't decided whether to have eTuner or Status Tuning do it.
Did you get a disc with it? Map sensor?? Universal Harness???
Try emailing Cihan (eTuner). I dare say that he would be willing to help.
Also, check his forum. Lots of info.
Edited by iamhe77
*sigh*
Here I am, trying to be helpful and supplying you with the link to eTuner all the while keeping the post nice and tidy... and you have to go and use Google. :)
On a brighter note, I have been talking with Cihan for some time about the eManage and while he was not overly familiar with the NM35 to begin with (who is?) he has become quite eager to see what the engine can do with the piggyback.
I have asked about a minimum of 200awkw (a "giggly school girl" target of 250awkw) with better fuel efficiency (required) in a RELIABLE tune.
He seems to think that 200 is entirely possible at the least.
Edited by iamhe77
You shouldn't need to lift the bonnet - all connections are normally made at the ecu.
the price isnt too bad for a full tune!
im guessing he is in melbourne?? i might have to find someone in sydney to do it, i know a great tuner, but they only have a 2WD dyno :D
That's INSTALL and tune... I think :)
I do have the support tool. Apparently it is on the installation disc.
Let me know what you need if your does not include software.
Would offer the ol' switch-a-roo... So you send down your eManage, I get it hooked up to my car, tune, send back... but then I remembered that I have a full exhaust and a HiFlow, so not really a tune you would find helpful, I suppose.
Could probably use my mates car as he still has the OE turbo.
He does have Fuji exhuast (OE front pipe & dump) and an ARC intercooler, but that shouldn't make much difference.
Edited by iamhe77
lol youd be surprised what an exhaust and intake can do to a tune!
thanks for the offer but if i was going to that much trouble id just drive there. ill see who CAN tune them here in sydney first before i explore his tuning house.
just need to get this baby wired up :)
Well....if Iain can get me one of those gizmo's too we could always do a roadtrip and come say hello :/
Get the tune's done, I'm all for better fuel economy and any added horsepower (old skool!) would be awesum lol
i found it the silvia nsw forum that i moderate. it was on there for $450 with all 3 looms, the MAP sensor and loom and a loom for a wideband. it was a steal so i got it :)
and i now have it in my hands, well, its in the garage
Cool, I'll be on my way around to collect it in 5 minutes :)
That is a good price, I had a quick squiz on Ebay to see what they were going for. I would have gone down the NisTune road but it appears the M35 computer doesn't like the current versions of the NisTune boards available.
Let us all know how you go with the E-Management Ultimate, sounds like a cost effective solution instead of replacing the whole ecu system.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
