Cool, I'll be on my way around to collect it in 5 minutes :)
That is a good price, I had a quick squiz on Ebay to see what they were going for. I would have gone down the NisTune road but it appears the M35 computer doesn't like the current versions of the NisTune boards available.
Let us all know how you go with the E-Management Ultimate, sounds like a cost effective solution instead of replacing the whole ecu system.
Let us know how it all goes, I did a bit of work on the ECU pinouts and have put together this drawing. There was some common inputs that I couldnt find / stopped trying to find on the harness like boost & O2 so if you know what pins these are then let me know.
ECU_Pinouts_Model__1_.pdf
well, pending avaliability next weekend - and thanks to your diagram - ill install it and get it running (with everything unadjusted) to make sure it works. then it will be a wait for the mods to happen before a drive to melbourne for a tune!
thanks for the offer of help, ill post in here so its available to anyone else that might be doing the same thing
No problems, Ive been waiting for a fully tunable ECU alternative, like FLASH'g the existing or aftermarket ECU but no one has done this yet. Im using SAFC2 at the moment and its working fine but not very tunable.
ok so im set to install this on the weekend.
the only thing that worries me is the settings on the actual unit, the jumpers, and also the firing order for ignition
in my S15 i had to wire 1,2,3,4 to 1,3,4,2 due to a 4 cylinder firing order, i destroyed 2 coilpacks with incorrect wiring, and i dont want to risk that on this car.
they mention V6 engines, and with nissan being nissan they will probably have kept it fairly standard config. im going to google emanage ultimate installs on a VQ35DE engine from the states, i believe they act the same, even if the ECU is wired differently.
fingers crossed!!!
ok here is an install doco for G35 (US) that looks pretty good. ignore the wiring to the ECU, however his technique and setup is good, and it covers some nissan 'problems' etc.....
DandyMaxEUWriteup.pdf
may as well keep all the Emanage Ultimate stuff in the same place. make it easier for other guys to find and us to assist with
so once ive done my install, are you gonna drive to sydney to get me to do yours too?? :)
cheap rates :):P
cheap rates :):P
Haha. You would have to be bloody cheap.
Remember I can get it installed & tuned for a damn good price.
Edited by iamhe77
cheap rates :P:P
Ahem... I do hope you are referring to the E-Manage Ultimate :)
I'll be interested to see how it goes and what you think of it after it's had an optimal tune :D
I assume you are going for high output rather than fuel efficiency ;)
But I'm sure you can adjust that on the fly or atleast with a laptop running windows?
I've got a apple laptop so that wouldn't be too good for the whole USB software adjustment etc.
ahh yeah damn i forgot you were already IN melbourne for that tuner lol
yeah you can tune it on the fly with a laptop, but id be doing it on a dyno so its done properly.
ill be tuning for less fuel down lown, and more power up top because i drive easy around the city where i need economy, but when i put my foot down i dont give a shit lol
+1 (or is that +2?)
so yesterdays install didnt occur. the pin layout diagram i have may be incorrect. i was metering out +12v and 0v and neither of them were correct. so either i cant use a multimeter anymore, im reading it backwards, or the diagram is incorrect.
not sure what im going to do at this stage.............. might try again when i dont have a headache lol
Hmm... Too many variables there.
Perhaps ask URAS (Trent from Status Tuning - here in Melb)
Also, check out his eManage Ultimate thread.
Edited by iamhe77
nah no updates mate, with mothers day yesterday i didnt get a chance. ill see whats on this weekend before i give it another go. im prepping the wiring so the hopefully ill just need to plug it in after i crimp the wires
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
