the 3.5L were only available in the PM35
so its for a PM35. we called it a PM as the P means later model or something which we seem to call a 'series 2' in other cars.
My understanding after trawling for Sway Bar part numbers is;
M35 & PM35; both RWD as these share front end components with 2WD V series & Z33.
NM35 & PNM35 both AWD. Obviously, as you say; "P" denotes series 2.
  • 4 weeks later...
I can get map tracer software and writer for reflash M35 ECU but cost around$6000-$7000.
Software and writer( writer is for only M35) is for import ECU (in Japan)only.
So probably software can not use Australian Z33 Z34 etc ecu.
This means I think English software and writer can not use M35.
How many people want to realtime remap ?
If many people in Sydney I can buy it.
Or Im thinking me and Japanese tuner(he is in Japan) joint then make map for Australia fuel.
Is this interesting?
I have M35 std data so I know about M35 map.
But I do not have writer so Im thinking joint to Japanese tuner.
Me and Japanese tuner will make map for Australia fuel.
How much would you like pay reflash ecu.(your ECU send to Japan and install map data for Australia fuel)
Main thing is to remove throttle restriction and speed limit Toshi. If you can do that you'll have a queue!
A map for Australian fuel taking into account our mods, and being able to be done in Australia, is very appealing.
How much are you looking at charging? How much would you have to charge to make it worthwhile?
Correct, the fuel and timing would be good but I have an Emanage for that. Im interested in a remap of the throttle to connect it to my foot inputs. It seems reflash companies in Japan charge a premium for that so perhaps its difficult to do? What sort of time frame as I need it within a few months Toshi.
If I have tools I can remove speed limiter.
What is remove throttle restriction?
Are you talking about electric throttle?
Do you want to open faster than std?
I know throttle map so I think its able to open faster but power is same.
Looks like std map not good response around 3500rpm and 4800rpm if boosted up.
So ecu map need remap for Australia fuel.
I do not know how much can I charge.
So Im asking.
Well we'd obviously like it as cheap as possible Toshi, but you need to stay in business! Do your sums and work out how much you need to charge?
G-Zone charge about $450+ depending on spec for a complete remap.
We discussed this in a different thread last week and there were a lot of people with Emanage's who would be interested in just removing throttle and speed limiter, not a remap. Is this possible?
G-Zone quote that price on their web site. Check out the recent thread: http://www.skylinesaustralia.com/forums/topic/362400-g-zone-for-m35s/
44,000 yen ($506) for a standard remap, plus 20,000 yen ($230) for throttle restriction removal and speed limiter removal. Most people on here just want the second part, they don't need the first part because they have an Emanage. Not sure if that's possible?
And yes, below 3000 rpm for throttle restriction.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
