Mate, I hope you do get something extra for having a Nismo ECU :blink: . You'd have to be annoyed at paying money for nothing more than you could get by cutting a wire.
Surely Nismo don't just disable that input and sell it for $800 or whatever?? That would be a huge scam if that was the case lol.
I can tell you this....If I put the Standard ECU or Impul on my car with the turbo I have on it its a Fat Black laggy POS.....4,800rpm before boost starts to climb. With the Nismo it was full boost by about 4,200rpm before the tune.....after the tune full boost by 3,200RPM and Cihan pulled some timing out because it was too reactive.
Kickdown has also been played with!
oh and I can do more than 171.5km/h. :P
I'll lay London to a brick that if a Nismo came up on IM you guy's would be all over it!.....it's the best plug and play mod you can get!...snipping the wire just let's you do burnout's!....well maybe not for Aaron :P
Edited by Jetwreck
i dont think it would still let anyone with a highflow do burnouts(stock ecu that is). without a high stall its only a little bit better...
i think my next challenge is to disable the attessa with a switch, and still be able to keep ABS.. the plug under the dash puts the 4WD light on, but i think it reacts the same and pushing the "synchro" switch.
which leads me to believe there is clearly more to the ECU than a throttle opening..
One of my test launches yesterday (with brake switch disconnected) caused the 4WD light to come on :whistling:, but this mod doesn't mean instant burnouts.
Our ECU's are very much like women; I don't think any of us guys really understand how they work, but we know what we'd like them to do better, LOL
LOL
yeh theres a plug attached to the OBD port, this is 'meant' to disable the 4WD. unplugging it certainly turns the 4WD light on, but it felt more so of 50/50 distro as i couldnt spin the wheels up at all and it was wet. but it definitely pulled as if the roads were dry..
i want more of a 0/100 lol
LOL
why don't you try one of these then....use to have one on our old R32 GTR....worked very well.
http://www.ebay.com....=item19c5b4b24f
sent off a question asking them if it works for the M35.
Would like to see what our cars would run on the Dyno just in RWD!!!
Edited by Jetwreck
it would be something I could consider..
but i wouldnt know where to start with wiring it in succesfully I cant seem to find a diagram for our attessa wiring system..
but isnt that more for being able to split torque to the front when you want instead of when needed.
it says that normal mode is just 'stock'
FFS!....isn't that what you want.....man your sizzled :P
It does for me. :)
Haha, yeah I know for a few of you guys it does. I was meaning for the majority of us with minimal mods, but you knew that & were just showing off ! LOL
I enquired about this one a while ago & it's never been used in a M35 yet. I can't see why it wouldn't work with our cars, but.....
OK, found the message:
"As far as I know no one is using one on an M35. If you want to take some photos of the G-sensors and connector under the center console I can certainly tell you if it is likely to work and I would be willing to refund your unit if it turned out not to be suitable after trying.
Regards Justin"
I really wanted more front wheel torque for those wet days when you want to get where you're going quicker & with less RWD "fun".:happy:
Edited by Commsman
Regards Justin"
dont you have a synchro button?
Yes I do :yes: But so what?
You're going to tell me that using syncro will engage proper 4WD, right?... Well when I do that it feels like I'm driving a 4WD with the front hubs locked. You know, harder to turn in tight spaces etc. What I want is partial or progressive front wheel torque, without the "lock up" feel.:huh:
LOL
did you unplug it and pump the break pedal 5 times?
i liked it, mine doesnt feel to jittery
yeh it doesnt do anything.. but i figured out full time RWD read the attesa thread.
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
