I think it is 79%. If no one else weighs in to say differently l can plug it in & do a test. I do know that I can't get above 87%, ever.
No dramas Leon :) Scott pretty much hit the nail on the head with respect to what I was getting at, as he wasnt able to get around the sub 35kph 'restriction' by going to a manual throttle cable I think you could say that when you put your foot down it does open up the throttle but the restriction is caused by a secondary set of 'safeguards' I guess. It sounds like Craigs ECU isnt partaking in those safeguards though. Curious indeed :)
nismo ECU maybe??
i have a long way to go before i find out :(
It could well be the Nismo. I noticed a huge improvement in responsiveness 'down low' when I put hte Impul in but I wouldnt go so far as to say that it no longer retards down low - particularly given the amount of black exhaust fumes Ive seen spew out the back when taking off (Not even with my foot 'down'!) :whistling:
Just had a quick look at the G-Zone description again.
They do say that the "option" they can supply with their remap removes the throttle restriction in a similar way to the Nismo ECU - by modifying the variable valve timing, electric fan and also "start timing (temperature etc)".
hmm... So maybe the vManage WILL remove this restriction... and because it can work with the vv timing, perhaps the Fcon iS can as well.
because there is no piggyback for the throttle. the vmanage can interrupt the VTC signals, but nothing we have can adjust the throttle itself. except the HKS because its a standalone.
im talking piggybacks. and put yours hands up if youre running a full HKS F-Con?
ohh wait, thats no one lol
Who cares! Oh thats right, you need to pass a yearly inspection, and if you cut the cel wire the car goes into limp mode... Oh thats right, its already going to be in limp mode so who cares again... lol.
Had a Haltech Platnum series.....go rid of it a long time ago!
Now have a Nismo piggybacked with and E-Manage Ultimate......I have bugger all low end restrictions with throttle or Cam's......as seen first hand by PN-Mad both in 2WD and 4WD!
+1 on that :yes:
I felt like I was driving a 1.3 litre Hyundai Getz auto after that....
Anyways, I might be interesting to see what a 3.5, with no throttle restriction ( I think), Less fancy electronic cams retarding, and shorter 3.5 final drives will do... apparently 8psi is OK to run properly tuned on a stock motor- in a Z achieving about 270rwkw.
Now- can someone suggest a ECU - I have F all knowledge about computers and that shit- anyone have ECU proven results on a VQ35deT?
+1 on that :yes:
No throttle restriction with factory N/A ECU's.
eManage Ultimate has been used in turbo or supercharged G35's, Fcon iS and V-Pro have both been used (again G35, V35 and Z33's), I'm sure the Haltech 350z Premium would be up to it and I guess APS with their piggyback could also be done (works on Z33, G35/V35).
I guess you'll need a universal harness though... unless the Z33 eManage Ultimate harness (thus the HKS Z33 harness) fits - we are trying to find out for my mate's V35 GT8, but I haven't seen a PM35 ECU pinout :(
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
