the 3.5L were only available in the PM35
so its for a PM35. we called it a PM as the P means later model or something which we seem to call a 'series 2' in other cars.
My understanding after trawling for Sway Bar part numbers is;
M35 & PM35; both RWD as these share front end components with 2WD V series & Z33.
NM35 & PNM35 both AWD. Obviously, as you say; "P" denotes series 2.
  • 4 weeks later...
I can get map tracer software and writer for reflash M35 ECU but cost around$6000-$7000.
Software and writer( writer is for only M35) is for import ECU (in Japan)only.
So probably software can not use Australian Z33 Z34 etc ecu.
This means I think English software and writer can not use M35.
How many people want to realtime remap ?
If many people in Sydney I can buy it.
Or Im thinking me and Japanese tuner(he is in Japan) joint then make map for Australia fuel.
Is this interesting?
I have M35 std data so I know about M35 map.
But I do not have writer so Im thinking joint to Japanese tuner.
Me and Japanese tuner will make map for Australia fuel.
How much would you like pay reflash ecu.(your ECU send to Japan and install map data for Australia fuel)
Main thing is to remove throttle restriction and speed limit Toshi. If you can do that you'll have a queue!
A map for Australian fuel taking into account our mods, and being able to be done in Australia, is very appealing.
How much are you looking at charging? How much would you have to charge to make it worthwhile?
Correct, the fuel and timing would be good but I have an Emanage for that. Im interested in a remap of the throttle to connect it to my foot inputs. It seems reflash companies in Japan charge a premium for that so perhaps its difficult to do? What sort of time frame as I need it within a few months Toshi.
If I have tools I can remove speed limiter.
What is remove throttle restriction?
Are you talking about electric throttle?
Do you want to open faster than std?
I know throttle map so I think its able to open faster but power is same.
Looks like std map not good response around 3500rpm and 4800rpm if boosted up.
So ecu map need remap for Australia fuel.
I do not know how much can I charge.
So Im asking.
Well we'd obviously like it as cheap as possible Toshi, but you need to stay in business! Do your sums and work out how much you need to charge?
G-Zone charge about $450+ depending on spec for a complete remap.
We discussed this in a different thread last week and there were a lot of people with Emanage's who would be interested in just removing throttle and speed limiter, not a remap. Is this possible?
G-Zone quote that price on their web site. Check out the recent thread: http://www.skylinesaustralia.com/forums/topic/362400-g-zone-for-m35s/
44,000 yen ($506) for a standard remap, plus 20,000 yen ($230) for throttle restriction removal and speed limiter removal. Most people on here just want the second part, they don't need the first part because they have an Emanage. Not sure if that's possible?
And yes, below 3000 rpm for throttle restriction.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
