Ecu need learning throttle close position and (TAS) throttle adjust screw if ecu connector or throttle position connector is removed, after adjusting timing , adjusting idle, when battery becomes flat or after changing batteries ,Z33 34 M35 etc
I think some people need this one.
So this is something different to the idle learn procedure? If so, I'd say EVERYONE needs it.
Would you care to elaborate on the procedure for this, please Toshi?
Edited by Daleo
I cant seem to find the Teps website, has it disappeared?
lol, the link in my sig hasn't changed... still works no problem
On top of that I think you might find the VQ35 does not have a throttle restriction.
They still use the VQ25det engine, but stroke it out using (at a minimum) VQ35de crank and rods.
Doesn't make it 3.5L though.
EDIT: just calculated it, 3.25L if you put VQ35 crank and rods in a vq25det (maintaining the same bore)
Edited by iamhe77
I've seen a 3.6L TEPS built VQ25DET on a link on here. The Flash web site that stole heavily from Fast and the Furious...
If VQ35 crank and rods make it 3.25L, what else do they do to them?
Nope, sorry... not 3.2L... 3.5 crank and rods make it 2.8L (2771.42cc)
Here is the TPS.
It means you can adjust the idle to some extent and also get more air at startup? And perhaps slightly more throttle position at stall or when driving which will explain the slight differences we are seeing on the Informeter.
Here is the TPS.
The difference could be that the Impul was able to adjust it slightly.
I will put the stock ECU back on and test in the next few days.
Cheers
Andy
Still doesn't explain how they get it to 3.6L :nyaanyaa:
As Scott said, to reach 3.6L they bore and stroke the VQ25det, then use a VQ35de crank and put in their own rods and pistons as per below
(ain't they puurdy :))
I spoke to Jetwreck and he said his nismo ecu not problem under 3000rpm.
G-ZONE said throttle controller and remap throttle map is same performance.
Scotty have throttle controller but its not good work.(This means Scotty changed throttle map but he could not fix under 3000rpm problem)
How is Ks rom?
Ks rom do not change throttle map.
If Ks rom fixed under 3000rpm problem its mainly std map problem.
If Ks rom can not fix under 3000rpm maybe throttle map problem.
How is Ks rom?
All correspondence I had with Ks stated that they cannot remove the <3000rpm restriction.
The cam advance map on the Vmanage seems fine, as in it is advanced at stall. The problem is the throttle plate no opening and it doesn't matter what you do to get around it as airflow is the ultimate problem. It looks like there is only two ways around it, to run the stock turbo or to go the cable throttle route.
Craig still cant launch his car unless he spools the turbo up which takes a few seconds. The Nismo still limits the throttle at launch unfortunately.
If its just throttle problem how is install big throttle?
Air flow more than std throttle.
I think wire can not install with std ecu.
If you take out electric throttle how to adjust idle and idle up?
Think outside the box Toshi, the idle can be adjusted with the adjustment screw on the side of the cable throttle, im using an EA Ford one I think.
The stock ecu will go into limp mode which is 1200 revs, then the Emanage will take full standalone control = WIN. :thumbsup:
Enlarging the throttle will work to some extent but im just sick of the whole thing, I want full control of the air and attached to my foot. What's wrong with a throttle cable anyway?
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
