hmm i might try that tomorrow then.
there is ignition timing and additional boost on the nismo - actually not sure about the boost increase.
well i know the arx MUST be tune differently as from factory it runs a few psi extra.. and who knows if nissan advanced abit of timing to compensate for the extra ass...
Getting back to informeter and modifying the signals from these 2 pots, when I made changes to increase opening from 80% to 90%, the informeter would read LESS than 80% (closer to 70% actually) and then the ECU would back off the fuel (cause it thinks I don't have the throttle opened as much as I do) so I would see the injector pulse width drop down (meantime I'm going faster) & of course the knock sensor would put an end to it pinch.gif I'm hoping for better results at the lower end of the spectrum though. There's more fuel at launch and that is where we want the benefit anyway soooo.... we'll wait & see.
seeing as i've got a wideband in maybe me n scott will also figure this one out. but im starting to think it may have something to do with the fuel map as Cihan cant tune the car under 3000rpm when in third, as if he floors it it will kick down to first and jump off the dyno..
so it could also be a possbility that the low end fuel map is muck, as mine does strange things according to the wideband, but once it gets to 3000rpm, ratio sits at about 12v and everything hammers
maybe we could talk Ian into sticking his spare motor on an engine dyno to see if Gihan can tune the emanage to suit! :P
Not that it would really concern Ian or I....but we do like to help when we can.
I think if the transmission has anything to do with it, just an engine dyno wouldnt work i dont think.. Cihan needs to do a track coughroadcough tune from standing still, to full ball in first. Maybe we can get around it with just that(i like to dream)
Now that's a generous offer :thanks: guys.
Edited by Commsman
just food for lhought guys
the voltage range on most tps's is 0-5V
when you hook up an ecutalk display you can configure it to show tps volts or %
but for the % to show correctly you have to calibrate it as WOT isn't actually the max range of the sensor
is there any way to calibrate your display thingos?
and has anyone run the throttle out of the car and seen how far the butterfly is open at 86%?
yeah we already know its a range calibration on the informeter, i mentioned that one page back. at 86% its WOT
thats not the problem. being BTW the ECU retards the throttle to limit torque, we want it back. at almost any cost :P
I reset the Voltage range for the throttle this morning on the the informeter and now see throttle in the 40% bracket when stalling. It was a very brief stall and not completed so this may be a little higher in reality.
I will try to get a proper number later today.
by doing the Throttle position reset or?
is there a way to do it in the informeter??
VQ's have twin TPS signals, 0-5v and 5-0v.
The 36% at stall opening is the big issue, not the 86% once it opens.
Perhaps the issue at stall is just an input to the ecu from the brake. Maybe the nismo has this turned off but for those of us without "awesome", we could just cut the wire....
my thought exactly. i said it earlier but im not too confident in exactly which wire that is.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
