Sort of worked...
Aaron and I went for a squirt today, he looked at the gauges while I drove. We found my ecu definitely opens the throttle 100% at launch, but only if the brake was off for a second or two beforehand.
I looked at the ECU diagram and found the brake pedal input wire, not knowing if it would put the car in limp mode or if the brake lights would work, I snipped the wire and backed the car out.
The brake lights worked, and now I had 100% throttle at stall. A drive told me the abs still operated and the takeoff was much better, with the car hitting the 4000 rpm stall limit off the line with little effort.
I will let you know how the car drives over the next few days and if there are any side effects but for now it looks like Pipster pointed us toward the holy grail. :cheers:
Yep and can't believe how simple It really was obviously scotts is running off a built box which means I'm also testing it out for the next few day on the stock box to see if it handles. Scott now has an advantage with the high stall.. On my gbox it's improved a little but because I have a 2000rpm stall I can't do much ATM. But In saying that I can now boost up to 8-9psi on stall with 100% throttle and launch the bastard much better than before. I cant believe we did it, hopefully this will save us over $1000 each by not having To go gzone or nismo anymore!
Woohooo, that's brilliant !
I'll give that a go myself. Will do the before & after tests under same conditions of course, to try & take the 'subjectiveness' out of the equation.
I love low (or zero) cost solutions that give great results. No one can be dissapointed hey
If you want to try it, its pin 55 on the ecu. Its a pink wire with a blue line.(around the middle of the plug.) Just make sure you tape up both snipped ends well. :thumbsup:
(Dont hold me responsible if you damage anything please.) lol.
i rekon the nismo already has this out of the box thats probably why we have better throttle response........
but this is a shit loads cheaper lol
can you confirm this by getting hold of an informeter and stalling it up, before chopping the wire?
would be interesting to know, as i know andys impul is only doing 36% on stall as standard
his is KNOWN to have the throttle limit.
are you guys 100% sure there IS a performance increase?
heres my theory, the informeter is reading the throttle input from your foot. the ECU limits THAT signal to 38% (or whatever) due to its programming.
i have an informeter mate, ill be driving to work tomorrow so ill check it out in the back streets. wont be chopping any wires yet
yeh because before when scott would stall, it would hold him at 2000ish RPM,, now it limits him to his high stall converter.. which means the extra opening has increased, i also noticed a 5psi increase from where it was before for mee..
im sure he did lol
im glad we all worked together to get past this problem :)
now craig and i cant son of rajab our nismo all over you guys :(
Does that mean if this works out everyone gets membership to the awesome forum? :nyaanyaa:
im sure he did lol
Nismo awesome is still awesome; but free awesome is the awesomest kind of awesome.:thumbsup:
'Cept for boobies...:thumbsup:
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
