i liked it, mine doesnt feel to jittery
yeh it doesnt do anything.. but i figured out full time RWD read the attesa thread.
yeah i saw that
i'd jack the car up all round (a la hover stagea) and see if the fronts are turning at all
this will tell you if its taking all the pressure out of the transfer case
  • 2 months later...
we need to change the title of this thread to "fixed the slow takeoff issue!" haha :)
so on a normal car like mine.. and someone who isnt really interested in stalling it up are there any gains from this mod if you just like to nail it off the line?
Short answer, YES !
Edit: OK, see Aaron's answer above for a slightly longer version :)
Edited by Commsman
Short answer, YES !
an even longer version is this
after a couple of hundred Km of driving, you'll notice your boost will drop, and perhaps other stuff.
you can get around it by putting in a momentary switch in line, press the switch, tap the brake, and your off again.
similar to what leons done!
I tuned in this "limp" styled mode, and its heaps better lol
Should I even bother with this? Did you and Scott put a switch in?
nah dont worry about a switch with the emanage. just go for another tune once you notice the weird limp mode. or when you next mod something.
i dont think scott put a switch in yours, i we definitely didnt in ours.
hmm.. so there is some sort of limp mode enacted? thats odd.. i might just solder on some connectors so i can rejoin it if required.. the ECU is mounted vertically on the wall of the chasis by the passengers feet isnt it?
yup. just infront of, not to the side. the one to the side is the Trans ecu
while we are on the topic of emanages.. do you have to run the ultimate on the m35? is the factory tune aggressive at all or very safe? considering i run LLPG injection and an exhaust i am trying to work out if its worth my time putting one in..
how hard is the install and tune?
the only other mod i am interested in is high flowing the turbo when and if it dies :)
appreciate your help.
hmm, if your car is running fine now on LLPG, and your car is fairly stock, I wouldn't recommend going Emanage.
My car was running pretty good on LPG after the conversion but after installing Emanage and getting it tuned the changeover process turned to shit.
This is not the tuner's or the Emanage's fault. I think the LPG system is tuned to run fairly rich to start with to eliminate any fuel feed issues.
However once the emanage is in and the car is tuned and the mixtures are leaned out, that's when issues starts to happen.
Pretty much everytime I start my car, and the gas kicks in the engine would stall or suffer from fuel starvation (engine is barely turning over and even if you floor the pedal it won't rev at all, the AFR goes out the roof). This issue occurs almost 100% on hot days and after you've driven you car for a while (i.e. the engine is hot).
However, on very cold mornings the car usually kicks over to gas perfectly. Which leads me to believe that due to the nature of LiLPG, its most likely that my feed issues are stemming from the fuel evaporating in the fuel lines?
Anyway, I've discussed this with Seaview Gas Conversion - the same mob that did our cars. They asked me to go visit APS performance (across the road) and get the car on a dyno so they can do some checks. I'll also be asking them to fit in the biggest f**king fuel jets available as my current ones are restricting me to 250awkw....(even less as when I had the car retuned last month Cihan said the AFRs are all over the place and couldn't tune it safely over 5k rpm).
Edited by ironpaw
hmm interesting.. let me know how you go on the dyno.
my car is kind of the other way round.. on cold mornings less than approx 7c on cutover it will almost stall and sometimes does.. on hot days cutover is much better and pretty much seamless.
i took it to the snow a month ago and to avoid the issue i simply manually cut back to fuel before stopping the car.. then drove it for about 5 mins before manual cutting back to LPG..
All in all i am very happy with the LiLPG car goes real well only criticisms is i only get about 230-250's per tank (all traffic) and i get a gas smell when i use the heater.. (need to take it back and find the leak).
But all this aside i want some more grunt!! bleed valve is coming going to set to 1bar so that might tie me over for a bit :)
Edited by Sage222
I get the same issues, except I barely get 200km out of a tank. 230-250 is pretty good LOL....
And yes I'm getting the gas smell when I use the heater...wtf??? coincidence!??!
gotta be a minor leak in the engine bay.. gonna get out the suds this weekend :) (spray some soapy water on the fittings while the engine is running and you will get bubbles if its leaking).
I actually get 14L per 100 on the freeway! wrapped about that.. though urban is shite!
Though filling up at 51c per litre i cant complain!
Edited by Sage222
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
