GTR pumps are noisier than GTS-t pumps.
Most of the import nissans have a switching current thing happening so the pump runs slower at idle and makes less noise.
Silvias and 180s definately have it. I'd be pretty sure the GTS-t has it too if your pump gets noisier off idle.
Only way to be certain it's ok is to have it checked out by a pro if your really worried
Dan. Yes it is normal.
All gtr fuel pumps are like that..
The one I just got put in is the same.
at idle is is a slight hiss and as soon as you touch the accelerator, it goes in to a high psssss sound, then back to low when it gets back to idle..
it's fine.. don't worry about it..
I put a Bosch 040 pump in my GTS-T about a month ago and you can hear it at idle sometimes but when you get going I can't hear it at all (engine noise and other noises take over it).
Was the pump mounted intank ?
Jay95R33 - I have a mate that has a R33 GTR and you can't hear the pump in his car either. That's why i was getting worried. Maybe they have insulation to stop you from hearing them.
But, after making some phone calls, getting the pump checked and judging by the comments on here, the pump is 100% fine.
GTST - It is a R33 V-Spec pump so i'm not sure of what it flows, i just know it performs much better then a standard one !!!
*GTST pump is 135 litres per hour and supports 300 bhp at standard pressure
*GTR pump is 190 litres per hour and supports 420 bhp at standard pressure
*Bosch 910 pump is 200 litres per hour and supports 450 bhp at 73.5 PSI # 0 580 254 910
*Bosch 975 pump is 228 litres per hour and supports 500 bhp at 73.5 PSI # 0 580 254 975
*Bosch 984 pump is 228 litres per hour and supports 500 bhp at 73.5 PSI # 0 580 254 984
*Bosch 044 pump is 330 litres per hour and supports 730 bhp at 73.5 PSI # 0 580 254 044
*Bosch 040 pump is 235 litres per hour and supports 520 bhp at 73.5 PSI # 0 580 254 040
As found from here
I'm using the Bosch 040 which cost $340 supplied and fitted.
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
