pushead - I took off all my intake piping which was suprisingly clean, and gave it a bit more of a clean.
I then cleaned my afm and then took off the thottle body and cleaned that. Out of the lot the throttle body looked the worse (thin layer of very thick oil around it).
After putting it all back i found a noticible difference in throttle response and felt like it came on boost a bit smoother.
It will only cost u 1 bottle of carby cleaner. Would be interesting to see before and afters on a dyno of doing this.
  • Replies 80
yes it does... it always does... no matter what mods, tyre pressure, clutches all come into play.... put a decent clutch in a stock car and u will probably chop almost half a second off the time.
I made 140rwkw at BMT.
Mods:
* 3"dump/front
* 3" cat back (crappy cat is still the bottleneck)
* Bleed valve set at 0.7 bar (~10psi)
* K&N Panel filter in stock air box.
* Pineapples (prolly wont affect a power reading)
I couldnt give a rats ass what rwkw I've got. I ran a 13.83 @ 101mph last weekend which is similar to others with 180+rwkw.
nigasnt is 100% correct, rwkw dont mean squat!
thanks for all your input ppl. I was wondering ok, instead of measuring in rwkw but 1/4 mile times, did anyone measured their 0-100km/s? if so what results? reason why i asked is most street drags are 0-100km times, please also note i do not encourage anyone to street drag, but im sure we all have done it some stage :P:)
i think bmt dyno is lower (someones already prolly said what im saying b ut i cbf reading the whole thread)
so is racepace's dyno, best way to find out is either test on anotehr dyno or simply ask the guys at BMT if that's the average power they have seen on cars with your mods, they'd know best :P
This dyno is way low for sure!!
RiggaP said he ran a 13.8 or something with a dyno result of 141rwkw... For your car to run high 13's you have to be pushing about 180rwkw plus..
I had my r31 dynoed at Goodguys in bayswater and got 160rwkw @ 12psi and I know my car is probably good for low to mid 14's..
Take it to the track, see what sorta MPH you get
    • Not specifically the revamp Toyos. In the past I've used Nitto NT01s, which were essentially the same compound as R888 with a different pattern (that's what the internetz said, so just be facts). I did like the NT01, progressive fade, didn't go from grip to 0 grip in a split second. If you look at the serious street/track guys, most are either on Cup 2, A052, A050, AD09, CR-S or AR-1.
    • I have one of these! It is absolutely useless. It provides not nearly enough force on the bolt, it just slips over anything that is not finger tight. And if it's finger tight, you can use your fingers.
    • You have to take photos of the car in Victoria with a timestamp. So if you have big aftermarket turbo in your engine bay, your car is simply not getting a RWC and you'll be doing a lot of returning to stock, and re-modding after about 90 days (because cars that have had a RWC can be audited after the fact). The law I'm kinda ambivalent about. I can see the logic and the writing on the wall, Cobb etc would be well known for selling to 'wink wink off the street usage' but in the real world everyone knows what they do and where they end up. It'd be like someone selling guns in Australia but "only to people who have a proper licence" but selling them outside of Bunnings instead of sausages to anybody. Like RWC's, and VASS's and EPA, this is enforcement of the actual existing rules. I haven't looked into it but there (should) be a way for people to legally pass their tuned car to be within the rules if they can prove they pass emissions laws that are applicable. If there's not then that's another story.
    • Interesting post(haven't watched the vid). I'm surprised companies can be fined for selling products that are specifically meant for certain applications.  How can you force a customer to use or apply your products in 100% the way intended? People have been misusing products since they were invented. Heck, I ate dessert last night with a soup spoon. Does that mean the spoon manufacturer could be fined? And what of the customers who actually want to use the product for its intended use?   I'm sure we could discuss and debate this for a while, but this is an introduction thread and I dont mean to take over it.
