pushead - I took off all my intake piping which was suprisingly clean, and gave it a bit more of a clean.
I then cleaned my afm and then took off the thottle body and cleaned that. Out of the lot the throttle body looked the worse (thin layer of very thick oil around it).
After putting it all back i found a noticible difference in throttle response and felt like it came on boost a bit smoother.
It will only cost u 1 bottle of carby cleaner. Would be interesting to see before and afters on a dyno of doing this.
  • Replies 80
yes it does... it always does... no matter what mods, tyre pressure, clutches all come into play.... put a decent clutch in a stock car and u will probably chop almost half a second off the time.
I made 140rwkw at BMT.
Mods:
* 3"dump/front
* 3" cat back (crappy cat is still the bottleneck)
* Bleed valve set at 0.7 bar (~10psi)
* K&N Panel filter in stock air box.
* Pineapples (prolly wont affect a power reading)
I couldnt give a rats ass what rwkw I've got. I ran a 13.83 @ 101mph last weekend which is similar to others with 180+rwkw.
nigasnt is 100% correct, rwkw dont mean squat!
thanks for all your input ppl. I was wondering ok, instead of measuring in rwkw but 1/4 mile times, did anyone measured their 0-100km/s? if so what results? reason why i asked is most street drags are 0-100km times, please also note i do not encourage anyone to street drag, but im sure we all have done it some stage :P:)
i think bmt dyno is lower (someones already prolly said what im saying b ut i cbf reading the whole thread)
so is racepace's dyno, best way to find out is either test on anotehr dyno or simply ask the guys at BMT if that's the average power they have seen on cars with your mods, they'd know best :P
This dyno is way low for sure!!
RiggaP said he ran a 13.8 or something with a dyno result of 141rwkw... For your car to run high 13's you have to be pushing about 180rwkw plus..
I had my r31 dynoed at Goodguys in bayswater and got 160rwkw @ 12psi and I know my car is probably good for low to mid 14's..
Take it to the track, see what sorta MPH you get
    • A bit of data is always good, beats the Facebook experts with their opinions I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
    • Correct And whatever you do, don't use an oil pump gear, especially the one that starts with the same letter as Santa and the last letter ends with the same first letter as Lagoon. Get a proper oil pump, like a Nitto, Tomei, etc. and make sure you invest in a big fk off sump. Won't go into too much detail, but I am sure it caused my previous built motor to go bang.
