  • Replies 80
Originally posted by SLYWPN
This dyno is way low for sure!!
RiggaP said he ran a 13.8 or something with a dyno result of 141rwkw... For your car to run high 13's you have to be pushing about 180rwkw plus..
I had my r31 dynoed at Goodguys in bayswater and got 160rwkw @ 12psi and I know my car is probably good for low to mid 14's..
Take it to the track, see what sorta MPH you get
170rwkw for a high 13? i dunno about that...
i only have 142rw according to goodguys and sam ran a 14.08 @ 93MPH running 10psi. When it was on the dyno it was running 14psi... i guess its more the driver than power.
Guest RedLineGTR
OKay your results at the 1/4 mile depends on the driver/conditions/mods/experience etc...with dyno results when your getting shit tuned and added to your car...stick with one workshop then u know how it rates in the kw scene..if u want high readings go to AVO and see what thier dyno reads..they are know for high readouts...like mentioned rwkw dosent always mean alot it depends how u use it and put it down to the ground..
Guest RedLineGTR
tuner also have different styles of how they like to tune sometimes that ask u sometimes they dont... u can tune your car to be reliable and have great responce or u can have it tuned to its full poetenital thoe risking reliablilty depends on what u want and what the tuner and do for u.
Originally posted by pushead
i wouldnt mind now taking my car to the stripes. Want to see my 1/4 times. :P Thanks all for making me feel at ease with my results.
ive got some house paint somewhere u wot have to take it i will bring it to u with a roller... u want 2 fat stripes down the middle or just one? :)
Today just dynoed at BMT, had some dramas coz one of my coil packs did not work above 10psi so at 9psi made abt 147rwkw mods r:
SAFC2
ITC
3" 5 zigen exhaust system cat back
apexi pod filter
ARC FMIC
tomorrow gonna fix up the coil packs and up the boost to 13psi. Will let u guys know the figures
cool man i think my car is running 11 or 13 with 141rwkw at bmt dyno. mods are
SAFC (1 :D)
i have no idea what an ITC is lol
3.5" HKS superdragger cat back with 3" hiflow cat and front pipe
k&n filter
and thats it with power mods i think once your coil packs work and use more boost you should get more power me thinks.
should be good to find out what the results are
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
