a lot of people say that a 3" exhaust system is far too big for a naturally aspirated engine, and swear buy putting a 2 1/2" is buy far the best option.
im interested to hear what systems people are running on there n/a's and there 2 cents on the matter
which do you think is the better choice? 3" or 2 1/2"
Edited by j-qual
https://www.sau.com.au/forums/topic/266913-exhaust-size/
Ive got 3 inch with the car
havent driven one with 2.5inch
I get heaps of complements with the silencer out sounds insane, with silencer in it sounds quiet as stock
Performance feels better than standard exhaust aswell i think
https://www.sau.com.au/forums/topic/266913-exhaust-size/#findComment-4554426
hey, i got some 2.5" twins n it sounds fine, however i spent like $200 on a hi performance muff.
before i had a str8 4" cannon. = i couldnt hear anyone inside the car whilst driving.
NAs are alot louda than FIs id so if you like the big 3" i sujest a gd muffla = still sounds sporty and you can hear the cd player playn aswell :)
https://www.sau.com.au/forums/topic/266913-exhaust-size/#findComment-4554476
g'day james,
this topic has been covered quite extensively throughout the forums. it was proven that you can get away with a 3" system without too much loss of volumetric efficiency on an R34 RB25DE NEO however on an R33 a 2.5" system is considered ideal.
in your case if you are looking for an increase in peak power go 3" and if you're looking for response along with a mild increase 2.5".
have a search throughout the forums and you'll find loads of info supporting those.
https://www.sau.com.au/forums/topic/266913-exhaust-size/#findComment-4554552
yeh thanks guys and girl for ur input on the topic..
i thought the 2.5" was the right way to go...
im just worried about the car being to loud once i get the system fitted. atm i have a 5"canon on it and it sounds like shit (came with the car, i thinking its a no brander).... so wanted something sounding a little meaner.... i was gonna change the canon but as i said worried about the loud deep drone most na's have. and now im thinking of putting a fresh system in it...
r33 na's are stock 2.5" yeh :/ ?
https://www.sau.com.au/forums/topic/266913-exhaust-size/#findComment-4555860
gday buddy,
i just got the exhuast done on my 33 n/a. i was keen on a 3 inch but every place i went to said there was no way they were goin to put one on it, its just too big for a n/a, and lacks pick up somethin shockin.
i went with a 2 1/2 inch, extractors, metal cat, and straight through muffler, the resinator is comin off soon but i think it sounds awesome, has a really mean idle, and all the way through the rev range.
thats just my 2 cents worth any way
https://www.sau.com.au/forums/topic/266913-exhaust-size/#findComment-4556334
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
