I've got my mines chipped ECU for sale which i used in my AUTO - this will suit both manual and auto series 1 r33's, im not sure if it works on series 2.
Specs are:
- Removed rev limiter
- Richer maps to handle hiflow turbo + breathing mods + ~15psi boost. AFR's were at 11.8-12 on boost and ~15.1 AFR cruising.
- Annoying boost cut/r&r removed. I'd log a 5.1v @ 4500rpm and it wouldnt even hesitate to rev.
- would give me 460km to the tank +/-30km depending on how i drove.
Im after $300 + post. by far the BEST bang for your buck mod - you'll notice the power difference instantly even on a standard setup.
I can be contacted via PM or post here.
Pics will be up soon.
Cheers,
Joe
https://www.sau.com.au/forums/topic/267051-mines-ecu-for-r33-gtst/
not sure on an actual figure mate but i would estimate around 210-215kw when i was running around 10psi, i cant comment on 15psi as i wasnt getting traction at all but it felt awesome. believe me, if you had this in your car you would be confused as to why these things are going for so cheap!
Yeah mine has 201kw with standard ecu and injectors on 13psi, did yours have bigger injectors with the mines ecu?
And wats the go if u wanna go run 18psi with this ecu, is there much stuffing around?
where ur location?
sydney west
nah mate it had standard injectors. to boost it up to 18psi you wont need much work - just turn up the boost lol.
either way i wouldnt do more than what i said in my first post without getting on a dyno and checking that your AFR's are ok.
im interested. Is it good @ fuel and air flow tuning?
read my first post mate, all the info is there. its not a tuneable computer hence the reason why its so cheap. you just plug it in and off you go.
if you wanted to tune it you'd strap a emanage blue or ultimate to it and you'll be sweet. it will still cost you less than getting a full aftermarket computer if you wanted to go bigger injectors etc etc later on.
Specs are:
Cheers,
Joe
Is it still for sale?
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
