ok everyone.
i have decided what i am going to be doing with my R34, RUNVS2 aka Miss Betsy.
No, i am not turbocharging,
im supercharging :/
oh thats right, and no, i am not taking the piss. this will be actually happening.
Currently i am in discussion with my tuner, my engineers, and the place ill be getting the supercharger from to make this all happen. it will all be very custom, and alot of $$$ will have to put into it, but in the end it will be worth it.
Ill be using a 800hp Vortech Supercharger, and stroking my current engine to 2.7 L
Please do not go telling me what i have to do and what i cant do. you will be wasting your breath as i will not bother replying to it. I have my team of professionals, they are the people i consult on any questions or queries i have.
anyway, i cant wait :)
https://www.sau.com.au/forums/topic/267076-my-final-decision-for-my-car/
  • Replies 66
Looking forward to seeing this! I saw it coming in a thread in the SA forum, good on you for doing something different! :/
Before I done the turbo conversion I was thinking about the possibilities of supercharging and I'd read a thread where someone had actually got quotes to make up the manifold etc.. now someone's going through with it all! good to see!
haha yeah i cant wait
im going with a centrifugal type supercharger (basically looks like a turbocharger). so really the only things that have to be custom made are the brackets for the supercharger itself and the piping for the intercooler :/
So your doing this (and all of your past work) out of your own pocket? Damn. I want your job.
lol yeah i am. this wont take 6 mths to do tho. its gonna be a lil while....but i would like to consolidate my loan and credit card hopefully by the end of the year....and well maybe get some extra coin for the engine rebuild too hehehe :/
Also, just curious. Do any of your mechanics have any estimate on what sort of power this thing will put out?
um over 500 rwkw and thats just from the supercharger. thats not incorporting the fact the engine will be stroked to 2.7L
will be a great project to see develop
so is that a constant boost pressure of 26psi!!
goodluck with this
no its not a constant boost pressure, unlike turbos, that have an aggressive boost, superchargers are progressive thru out the rev range
Good decision mate...
But the question is...will you miss the SSHHTTTT sound? :)
hehehe never had it to begin with :)
wow. good luck with your build. just be careful going from an n/a to over 500 atw
she wont be a daily driver anymore.....and ill be doing courses in advanced driving as well!
What mods to the bottom end need to happen?
basically we are going with a RB26 Crank, Aftermarket RB26 Pistons and Aftermarket RB26 Conrods + all the machining and what not that has to be done aswell.
Im choosing to go this option as it will stroke the engine to 2.7L
I dont have to, but im going to lol
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
