what are the cheapest adjustable ones available for rb25det and who sells them? or if anyone has a set of standard ones il buy them off you coz i got a head and it only has one with it so i need to get another set or just one but i dont know which one i need. pm me if you can sell me second hand ones or post here to tell me the cheapest new ones available
https://www.sau.com.au/forums/topic/267139-rb25det-camgears/
i dont have any adjustable ones at all at the moment. i got the head and some parts were in a shoe box. there was only one standard cam gear in there. so i wanna get some standard ones if anyones selling them or some cheap adjustable ones. but i read on a thread on here not to use cheap ones. why is that? il buy secondhand standard or adjustable ones of someone also
  • 4 weeks later...
