Description:
Make/Model: Nissan Silvia q's
Year: 1993
Kilometers: between 115xxx - 120xxx kms on body, 92xxx on motor.
Transmission type: Manual
Engine: SR20det redtop
Colour: Black
Modifications:
-GKTech front, dump with flex and full exhaust system, with de-cat pipe.
-ISC 52mm Alloy Radiator
-Bosch 040 fuel pump
-strut brace
-FMIC core and piping sprayed black for stealth look
-pod filter
-r32 front and r33 rear brakes with r32 BM44 Brake Master Cylinder and S15 Brake booster and r33 handbrake cables. brake retains 4 stud pattern.
-Gold Koya Drift teks 17x8 fronts &17x9 rears
-GKTech OMP Style Steeringwheel
-Greddy Boost gauge
-dark tint all round
-alarm central locking & immobiliser
-old pioneer MP3 deck
Roadworthy Certificate: No
Accident History: None while ive had the car
Asking Price: 7500
Contact Details: PM's at this stage as my phone is playing up or email SIL_VIA_S13 at hotmail.com
Other Comments: Ive owned this car since 2006 and bought it originally as a q's, but decided to ditch that and go redtop (have reciepts for motor ect...) car has been registered at Vicroads with the red top.
The car is unreged and will not be sold with rego, i was planning to use this time while it was off the road to fix the few things that was wrong with it and do some more mods, but my hours at work have been cut heaps and I'm kinda getting over the whole moddified car scene and blowing all my money on mods, I want to move out soon aswell so need to save money.
OK things that are wrong with car are.
- Diff is standard 6 bolt open wheeler and has heaps of backlash, i had a 2way in it but took it out again because i did'nt "use" it, and i went through 2 sets of new tyres within 8 months of normal driving.
- Gearbox has the normal crunch from 2nd to 3rd and could do with a new clutch as the one in it is just a stardard one, was planning on getting it rebuilt or doing the 25det boxconversion, but still perfectly driveable.
- still cant get rid of the spongy feel of the brakes after conversion, they have been bleed properly, I did'nt get around to getting braidied lines and a BMC stopper so those 2 iteams will/should make it feel hard as a rock. Also the HB cables needs adjustement as it come up pretty high easy done, car still stops on a dime.
- will need a tune
-AC needs regassing if you plan on keeping it in, never bothered me as i always drive with windows down.
-has a few small dings on the passengers side, just shopping trollery dents really
-central locking isnt working for some reason, could'nt be assed getting under the dash to fault find, but i assume it only a fuse.
-needs battery clamp made up as its just tucked in there not secured.
-rear tyres are shagged because of the 2way and rear camber
extra note:
I am NOT looking for any swaps, also any low baller offers or stupid questions i wont bother answering
I can sell without the drift teks for $7000, but you will need to organise your own rims as i dont have any spare
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
    • Any updates on this? Although not a stroker, nor built especially loose, my car has the exact same symptoms. Although I feel they were not there to begin with. Since rebuild with forged parts I have done about 40k kms and it feels like during the last 15k or so, the oil consumption has gotten progressively worse.  Compression test showed - what I thought at least - similar 10-10.5bars in each hole without oil. I have not yet done blowby test though, due to limited garage access. #2 plug is the looks the most foul and that was the one with 10bars. Nothing in the breather tank. I only recently disabled PCV and left only the hoses running from the valve cover via smallish tank to turbo intake pipe there and did some mildish 2nd gear pulls so the car was definitely on boost (1.4bar or so). Removed a hose from the tank and it was basically dry - meaning, the wipe I used had basically no oil on it. Last time I checked, the turbo and IC piping seemed dry as well (will have to see about that again after those pulls). For the past year and a half though, the car has been driven like a granny would for 99.99% of the time, since it mainly serves the purpose of carrying the family around nowadays. A lot of slow, stop and go city driving and most of the trips it barely sees any boost, but gets up to temp properly every time. Although there can be weeks it is not started at all. The car does not smoke, or at least not that I can see. (CAT is in place though). There is slight visible sweating at the Ex cam cover seal and I recently tightened the oil cooler lines as there was some mist on them too. It runs and idles extremely nicely and feels all around healthy. Like TurboTapin, I too am suspicious of my turbo. I have had IC pipes pop out from 1.6-2bars of boost a half a dozen times during the years. The turbo is a HX35/40 hybrid. So, a very similar mystery. Around 1500kms and a litre of oil surely cannot disappear to thin air. Apologies for the wall of text, not sure if any of the above is useful for best guesses/things to check next.
