Gday all
been driving my missus 1996 RS4 Auto Stagea
and at random times when i'm slowing to a stop the revs die and the car stalls
it's recently been serviced engine is completely stock
but has been filled with just plain unleaded fuel (unsure if that matters)
any insight would be greatly appreciated
thanks
Tyson
https://www.sau.com.au/forums/topic/267155-stagea-stalling/
when i first got my 33 my boss shouted me fuel but his fuel card only worked at the shitty servo with normal 91 and premium 95 or something, and even on the 95 stuff whenever i came to the traffic lights or a stop sign revs would drop to 100-200 and nearly stall, id hate to think how it would run on 91, this is with the stock ecu too btw. now with any 98RON fuel she runs fine never drops under 5-600 rpm
https://www.sau.com.au/forums/topic/267155-stagea-stalling/#findComment-4557339
i would head over to the stagea section on here there is a few threads about stageas stalling aswell as all the possiblities it could be. Personally i know a few who are running their stag's on normal fuel and have never had an issue.
Stageas stalling is common to an extent and most seem to be able to fix it rather easily....have you checked the filters and fuel filter.. they maybe blocked or dirty? your afm?
but like i said head the stagea section and you find how people fix them or determined what was going on..
Good luck!
https://www.sau.com.au/forums/topic/267155-stagea-stalling/#findComment-4558093
Sounds like your AFM
had the same prob with my stagea and R33
change out the AFM and see if that fixes it
you could probebly borrow one, only takes about 5mins, will be able to confirm befor spending money at workshops
https://www.sau.com.au/forums/topic/267155-stagea-stalling/#findComment-4560785
Usually caused by fault Air Flow Meter or Aftermarket Blow Off Valve.
Both are easy to fix, the AFM is the easiest and cheapest to test, you can borrow somebody elses, will only take 15 minutes, if no difference then it's probably related to the blow off valve. Aftermarket blow off valves that vent to the atmosphere (instead of recirculating) will cause most skylines/stageas to stall.
Also as a quick (temp) fix you can unscrew your AAC valve a little (it's a small screw on the intake plenum) this will raise the idling RPM and should make it a little harder to stall (will probably use a bit more fuel and have a less steady idle though).
https://www.sau.com.au/forums/topic/267155-stagea-stalling/#findComment-4562111
  • 1 month later...
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
