Haven't found a specific thread yet for this cold air intake mod. Anyone care to share what they ave done to get colder air in, or if thy ae instaled the official "powerduct"?
Bet there's a bunch of people who've made there own.
Share your work/secrets!
Your request is my pleasure.
See this link of how I made mine and some pics of it.
http://www.skylinesaustralia.com/forums/M3...html&st=140
I fitted a piece of foam glued to a piece of L shaped plastic like the other plastic I used to seal off the front.
Cheers
Andy
Cheers
Andy
I thought I saw that a while ago! Nice work; I like the home job coz thats what i wanna do. what about the air filter? What did you use there? Are you actually getting colder air u reckon?
I made one by using a tub (like an icecream tub but actually had nails in it) about 140mm square behind the LH headlight cut a hole in the base near the top and fitted a one litre castrol oil container (so that it was also black) with the top and bottom cut off going into a hole cut in the front of the top of the standard airbox. Sealed all joints except the one going into the airbox to make it easier pull apart and remove when necesary.
Gave me an extra 20KW and cut a second off my 1/4 mile time. (Just kidding). No way of measuring the improvement really but plenty of air gets by the headlight at speed. Unfortunately the LH corner took the brunt when I wrote off my S1 so now I will have to start again. This time I also have an air diverter and scoop (from the group buy) to fit so that should help.
I haven't actually measured the temp difference but I am sure I am getting more cold air. The difference is noticeable at the top end. A bit less breathless at higher RPM.
Along the leading edge of the bonnet there is a rubber seal that runs most of the width of the bonnet. You need to either cut off about 4 inches on the intake side to make sure the cold air can get in. Or you can do what I did and that is fit a piece of wire inside the rubber seal and bend the rubber with the wire inside 90 degrees so it is out of the way.
I am using a K&N filter. I am not sure there is any real difference with it but at least it isn't a reason to slow the air intake.
Cheers
Andy
or you could just get lazy and buy one!!!!
be prepared to get bent over by Nissan though
I am ready and lubed up :(
I might get one put it when I take it for it's 60,000 km's service which is due in about 1500km's.
It's close to $200 isn't it?
I want to keep this thing genuine, has anyone got any pics of what the actual powerduct looks like?
Geniune, pfft. Genuine rip off... A little bit of your time, some pinchweld and some black spraypaint.
Spend some time making something for your car, it's good for the soul.
Save your money for petrol :( .
Either that or eoi for stainless steel structure, tig welded, bolts, pinchweld, ready to fit; $100.
The queue begins here, I'll post pics if people are interested.
Edited by Daleo
Is this the thingy jig were talking about?
Has anyone gone down the "cold air induction" road? If so how much did it set you back, which system did you use, and what was the performance gain like?
That is the item. The factory one is a very neat piece, I just used a piece of flat 1mm stainless, rolled the curve into it, tig'ed a lip around the edge, used a piece of pinchweld from Clark rubber. Rolling the compound curve was the hardest part of the whole exercise.
It was the first thing I did when I bought my car, so I'm not sure of the gain, but too much cold air never hurt an engine :( . Nice induction roar tho'.
I agree with danny that it looses a small amount of bottom end power but the upside is the top end.
Consumption may be a bit worse. Maybe I will change it back and watch the economy for a while.
Edited by andy65b
actually good idea i might run a full tank with a pod filter and full tank with no filter and see the difference
$174 from memory
LOL!!
I guess you are standing in front of your computer at the moment?
Must be a bit tender to sit, eh? :D
LOL!!
Must be a bit tender to sit, eh? ;)
the only good thing that came out of it was that my wife didn't speak to me for a week....I didn't have to have 1 six pack holiday* all week!!!!
*Definition: Six pack holiday - Go to the closest bottle shop(1 minute away for me) - buy six pack - drink six pack before arriving home so the wife does not see - wait ten minutes - your on holiday! - e.g. wife's voice sounds a bit BLAH BLAH BLAH BLAH!!!....GOLD I say!!!!
Edited by Jetwreck
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
