hey guys. id like to fit a fmic and possibly coilovers to my 33s2 but dont want the hassle of getting defected or incase of accident getting claim refused.
i know that with intercoolers most of them cut though the frame/body (or where ever it gets cut) to make the piping fit which is obviously illegal, but what about the ones that use the original piping and only have the reo trimmed. are these deemed legal or still not because of the reo trimming.
or better yet can anyone put point me in the right direction of a company/s that do fmic that would be legal or is there somehow can you make a front mount legal for road use.
and with regards to coilover suspension i am pretty much after the same info regarding legality.
im so confused with all the laws regarding what can and cant be done so i thought someone might have a better idea on here
i live in qld btw.
cheers for your help all
pete
ARC, Blitz & PWR are all I know of that make turn flow fmic's for skylines. They are all legal and you won't need to cut anything.
Coilovers are a bit of a grey one. Seeing as they come out with coilovers technically. You have to keep 2/3 suspension travel and I think from memory it's not allowed to have adjustable height.
Front Mount Intercooler's are legal and you can have them placed on your mod plate paperwork (Although there is not a specific code for them it shows confirms that it has been installed in accordance with good engineering practice).
YOU MUST NOT cut through the front reo bar as it is illegal as it compromises the structural integrity of your front bar.
You can make cuts through the body where they are cut for a GTR as the body shell is generic (I have helped someone on here forward a letter to Qld Police for a defect of the same nature and had it pulled as a result)
My tip is to buy a Greddy (or similar type) front mount kit that is fitted without any cutting as that is what I will have for my wifes car.
Coilovers are fine as long as your car is legal height as I have never heard of police defecting someone over coilovers except in circumstances where they were too stiff.
cool. thanks for your help guys, when you say greddy or similar, who else would you say is similar to greddy. i have read about the blitz lm intercoolers that are return flow but as far as im aware i would need to cut the reo. do you know of anyone that does return flow that i wouldnt need to cut reo to make it fit. also would i need to get the fmic mod plated.
I would only have a mod plate as back up if you cut a hole in your car. If you dont cut you dont need one.....
Depending on your power output I would just go the Greddy LS. Ive got a no name kit on my 525rwhp R33 and its been going great guns.
Call Steve from Motion Garage 0407672023 as he does awesome work (Did both exhausts (Stainless) and cooler fitments (beautiful welding on pipes which are custom made) on both of my cars). He has also fitted heaps of kits like the Greddy Kits that are fixed without holes.
He is also be good for advice on what you want and is unbelievably affordable. I got quoted $1300 for a mild steel exhaust system and he did a custom made full stainless system for the same price and my power outputs have been awesome with no restriction.
The need to cut the rio bar usually comes from 300mm+ intercoolers in height dimension & is totally illegal here in Qld(cutting Rio). There are plenty of IC's that are shorter in height & will fit behind the front bar without the need to hack into the Rio. All you would then need is to run return route pipework back to the stock layout.
Your best bet is to ph Qld Transport with regard to Height Adj. coilover type suspension.
I know plenty with them & most who have the car at some respectable height never seem to have issues with the police with regard to having them in-however the only guaranteed legal option with their regard/to my knowledge is a set of TEIN's that have been installed professionally with a locking tab & certificate issued-ie by Fulcrum to be of a height no less than 100mm from the lowest point of the vehicle to the road surface.(Teins being not the only option here)
Personally I dont believe that the suspension is working to maximum efficiency when the car is at a height of 100mm as all the suspension geometry is out & without installing roll ctr adjusters & the list goes on to get it right-good road handling quality will be sacrificed, so you are flogging a dead horse all in the name of looking Low-rider Gangsta-but to each their own I guess.
hey mate
blitz do return flow intercoolers that run straight back into your original piping mines for a 32 but i didn't have to cut the reo bar which is illegal all i had to cut was the front bar coz she wouldn't fit heres a pic
cheers
No u can't make cuts thru the body.
Every turbo car with a fmic that has the piping going thru the left side inner guard has a defect, and there's nobody in town that can legally fabricate the body to make any engineer or qld transport happy... its getting rediculous.
I can't drive my car at all, also half of my mates.
I know GTR's have a hole in the R/H side of the engine bay just above the rail under the battery in 32's, this is covered by a plate that is spot welded and can be removed and the intercooling
pipe goes through there. its the same as having a GTR its a factory hole and is legal.
i think by the sounds of it going for a return flow would be the better option.
i suppose ill have to suss out whats on the market that will fit without cutting the reo.
going by the above post blitz should fit, anyone know any others?
also is it the height thats causing the reo to need cutting on most or width, length?
in regards to suspension, i think ill just end up getting a shock,spring combo.
bilstein shocks/whiteline springs etc. more than likely ill never end up taking the car on a track
so i dont think ill really need coilovers.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
