Guest gtr_monster
Hey guys and girls i sold the 33 so i got a few parts laying round i need to get rid of asap:
1. pedders coilovers 6500kms use - $750ono
2. trust rear bar in good condition - $100
3. veilside side skirts, small crack on one skirt - $60
4. Gtr drivers seat, needs retrim comes with rails for 33 - $150
got a couple of other bits i'll post up, will post pics asap parts are located in newcastle pm me for more details
https://www.sau.com.au/forums/topic/267235-r33-parts-for-sale/
Oh ok didn't know pedders make adjustable coilovers lol, so just to confirm, they're height and damper adjustables?
Are you selling the whole set?
some pics of yours would be good please, and do you know the spring rate of these?
thanks mate.
Guest gtr_monster
Will get pics up asap sorry guys just haven't had the time to take pics as the parts are at my misses place and i keep forgetting to take my camera around to take pics.
selling the whole set of coilovers to suit r33 gtst, i don't know the spring rate sorry guys, they are height and damper adjustable
Interested in the coilovers, but only if u findout the spring rate, and are u willing to post to vic if so how much to 3219?
  • 4 weeks later...
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
