Well i've seen alot of people cleaning Rb26 throttle bodies and ending up with high idle problems.
I am prepping the engine to go into the car and was thinking of cleaning the throttle bodies as it would be much easier to do now as the engine is out.
Is there any "safe" method to go about cleaning them without removing the sealant or whatever Nissan put there?
I looked at it today and all i can see is a fine grey line right around where the butterfly sits when it is closed...Is this the seal?
Or should i just leave it as is????
https://www.sau.com.au/forums/topic/267267-rb26-throttle-bodies/
ive cleaned 2 different sets on 2 different rb26s and never had an issue, sounds like all your doing is cleaning all the built up stuff around the throttle plate which is sealing it 100% and then when u install it with a slight leak around it just needs a slight adjustment of the idle valve to suit, though on both of mine i have never had to touch the idle valve and its perfectly normal.
i would like to see proper proof of this "coating" which is not visable in the slightest when looking at them.
Unless you want the "high idle" problem, leave them alone. You can't see them so they don't need to look "pretty".
agreed, dont clean them, they have a clear coating internally, there is a chance that the cleaning solvent u use may lift this thin lining and "yes" you will have a high idle which you wont be able to get down...
they should be cleaned in a hot spray bath not in solvent... just a tip.
Can they be dipped in hot water with mild soap and cleaned with a soft brush? Will this get off the carbon gunk?
My only concern with this method is them becoming warped.
What do u think?
Are you experiencing a problem you think is related to dirty throttle bodies right now, or are you just getting the urge to clean something? If the later, may a suggest a good coat of wax and some tire shine :down: Seriously though, if there is not currently a problem, I'd leave it be.
also stripped mine and cleaned them while building the engine.. no problems at all
and what clear coating?? theres nothing there.. i used solvents :)
when i say solvent i mean not the acid bath at your local machine shop :P
we use a strong carb cleaning solvent if we dont have access to the hot steam bath (same thing they clean cynlinder heads with)
I suppose its best to point out simply to those who want to clean the TB's that you use something that your sure wont dissovle / attack rubber or plastic.... if unsure stick to carby clean (can version) and a tooth brush.
Edited by URAS
So could you use a steam cleaner safely on these? or would I be better using some carby cleaner on them? I'm looking at removing the carbon build up around the throttle bodies while I have them off the car at the moment.
  • 5 months later...
ANyone tried this stuff
http://justjap.com/store/product.php?produ...=265&page=4
to summarize
""Tomei throttle coat
Lubrication & Sealing of the Throttle Butterfly
Tomei Throttle Coat will aid with the performance in smooth opening and closing of the butterfly which will increase throttle response. The lubrication properties will also aid by preventing the throttle from sticking and to eliminate rough idling and/or engine stalling. Improved sealing properties and efficient engine operations. ""
have been wondering about this to as reassembling motor soon!
Edited by noone
I've just had to replace all inlet gaskets including throttle body and plenum after nik at allstar garage discovered I had a vacuum leak when they were installing a nistune. He warned me not to alter anything on the linkages or anything that looks like it can be adjusted as they can be a nightmare to re-set. Maybe this is were people are having problems if they adjust something without realizing it.
I thoroughly cleaned mine with carby cleaner when they were off and i've had no problems. In fact the idle is the best its ever been.
  • 1 month later...
looking a Dcieve's post his throttle bodys have a black finish inside
is this the coating everyone is on about???
is it safe to clean the throttle plates and the area they seal against mine appear to have alot of carbon buildup??
thinking just carby cleaner rags toothbrush etc??
Edited by noone
okay would the info in this thread work
is it the same idea as the Tomie stuff I posted above????
http://www.skylinesaustralia.com/forums/Ni...+throttle++body
my throttle bodys look more like this ie silver bare inner walls only with more carbon build up
than the black inner walls in dcieves pic above
Am starting to worry bout this now
Me car developed an idle hunting problem after a drive through the hunter one day. I remember the accelorator stop fell off and I put the loud pedal all the way down. Could this strectch the accelorator cable or disrupt any other linkages to cause a problem?
agreed, we do every engine we build, just make sure not to use anything too agressive.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
