lol i'm from taylors.... never ever seen your car b4 let alone a blue r32!
i always see meggala around highpoint though... his car sticks out like the proverbial... oh, and you can't miss those plates :P
Originally posted by WazR32GTSt
i'm in taylors lakes (more of a north west but close enough)
blue r32gtst
  • Replies 70
Hey WLD747...I live in delahey...drive a white R34...This isnt my user name as my user name doesnt allow me to reply to anything... Seen a whole heap of skylines around the area but wouldnt have a clue who they are.....Maybe us western suburbs people should have a mini meet
west side. st.albans.
White r33 s2 Type M. big intercooler at the front. is mine.
have seen a fair few around my area. there is a gunmetal grey s2 r33 around my area, and a mad chick in a r33 two tone with blue flame stickers on her car. also around my area. ohh and a r34 yellow, drug dealers around my area.
Originally posted by WLD747
this is the latest pic cause the other one was last years pic.
hope you guys dont froth.
i tired not to spew :D
J/k.
Evil... you got your car from Karizma on Victoria St?
uLA32,
where in taylors are you and what car do u drive? i see a silver r32 sometimes and a gunmetal r32 sometimes also but that's all i know from the area.
i have also seen CNBLOW before... very nice white R34, and used to see a red R34 in the taylors lakes shopping centre but not for a while.
Waz.
I live in Delahey.
Burgundy S1 R33
19" dual 5 spoke rims
Fmic, with std type-m bar modified
Personalized plates (black with white lettering)
ps: if you know the car please doent quote the reg :D.
Will be up for a mini meet. How about Bunnings on Keilor-Melton Hwy in Taylors Lakes?
Im with you al...up for a meet at bunnings...anyone intrested??....thanks waz for the comment..thats my white R34...Ive seen heaps around but wouldnt know who they are... hey Dineth...seen your car in airport west....as im always round there.....
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
